2017 EagleTac D25 Ti Series
lebox97
illuminationGear
correct, the only difference between Aluminum and Titanium models is the body material (internals, circuitry, accessories, etc is same),
oh, and the Ti has white GITD tailcap switch button, instead of black.
there are several different LED available in general (CREE XM-L2, XP-G2, XP-L HD, XP-L HI ~ all with CW or NW options) ,
and several "219" LED specifically, so make sure you compare apples to apples...
the current/newest NICHIA LED EagTac is using is the 219c 4000K, and is 2 bins (close to 15%) brighter/more lumens than the 219b's used previously (Even though the warmer 4000K may appear to be dimmer than the 4500/4700/5000/5700K 219b's).
for other specific info, it is best to contact the Dealer who has what you are looking for,
as ET does not update specs page for every possible LED a Dealer may Order...
Cheers
PS: and yes there is a typo on the ET Spec weight ~ the Ti models are approx 30% heavier ~ empty, D25A AL is 0.9oz vs D25A Ti is 1.2oz
Looking at the D25A black versus the D25A 2017 both in Nichia 219, is there any functional difference or is it only in material?
jon_slider
thanks, your site shows both the black and ti use the same Nichia.
Here is the Ti Version w Nichia, that the OP is interested in, with the following brightness modes:
OTF Lumen: 100*/63/8/0.5
peartree_423
Any news on a possible 2018 version? I have the 2015 version and I would love to upgrade but the 2017 version seems almost identical..
hatman
USA
Not sure what you mean by proper Lithium support. But I'm certainly with you on hiding the strobe and special modes.
That said, I have the 2017 D25A in Ti and aluminum and the 2015 in Ti; I love them all.
When one turned up MIA I immediately replaced her.
Pentaprisma
I have the D25C Ti 2017.. wonderful light and beautiful tint with Nichia 219. The light is pretty bright still, good trade off for the tint in my opinion.
But since the D25A can also run 14500 3.7v batteries shouldn't the output be higher if not the same as the C version, since they both would run 3.7v batteries..?
Why is this, can somebody explain..?
