DaveAnderson
Thanks archer. I was able to stuff a little tiny piece of rubber under the spring and now the battery pushes forward when the tailcap is pressed. This seems to have fixed my problem.
Hey everyone, I just got a QS2L-X and discovered CPF while googling around for some clarification of the features.
I have the iOS app, and I may just be missing a setting somewhere, but how do you get the side button to light up? I've seen it flash red when accessing the "secret" programming mode following ftjandra's instructions, but I thought it also lit up green when the flashlight was on, and could remain on afterward for a specified time. I thought that's what the nightlight mode was all about, but the side switch never lights up for me at all in regular use (tactical UI).
Thanks for your help everyone, the thread already answered pretty much every other question I had when I showed up.
Hi Schmidt, you are correct about the nightlight feature. I had the same problem with the QS2L-X that I received today. Contacted their support department and he said that means your light is still in warehouse mode. There is a special menu you access to make a change and that will fix the issue. If you contact support they will walk you through it.
Joe
IOS 14 whacked the 47 app on both my phone and Ipad. It opens for 2-3 seconds then goes to the background.
