A light for a friend
RCantor
KC, MO
==================Flashlight Recommendation Checklist================
Online or in store or anything
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
_X__Up to $50. If the perfect light is a little more I'd consider it
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format: Any of these would work except the area lamp. It's for home use only
____I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
_X__I don’t know/I don't care. but it has to have enough lux so I'm not expecting a small light.
5) Emitter/Light source: 6500K CCT Accept no substitutes. :)
_X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer: Don't care, needs to be inexpensive and reliable
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
Greatly prefer NiMH AA, C or D. Will consider LiIon 18650. Integrated battery pack is OK if they're replaceable and not proprietary.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
_X__I don't care
Lux is the issue. I need 10K lux over a circle at least 8-10" in diameter from 3' away. A larger circle is better. A light that will give 30K lux and can run at 1/3rd power is great. The more levels the better. Runtime has to be min of 30 min, an hour is *much* better.
10 K lux minimum over an 8" or more circle at 3' away.
2-4', will need to produce at least 10K lux as above. More is fine.
_X__30-60 minutes (more is better. It needs to hold the 10K lux at least 30 min)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
__X_Not Important (A “night-stand” light).
An accidental drop is possible. I don't want to have to buy a new one every 3 months. It is not *intended* to leave the house. We all know how that goes. :)
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don’t know.
_X__Any size switch will do. Levels would be nice
One level would be fine, 2 or 3 would be better. No blinkies needed but no problem if they exist.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X__I don’t care.
____I don’t know.
15) Water resistance
_X__None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
_X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
None
​Thanks for your help, this is not the type of light I look for so I'm clueless.
xxo
The Mag 3C ML50 would be a good fit, 28K lux, plenty of run time, a 1/4 turn quick focusable beam (much better than the old Mags), 4 easily programmable function sets of 3 modes each, electronic switch, runs on standard C cells or AA's in an adapter tube (simple to make or can be purchased from Eneloop). Around $35 for the standard ML50L at walmart or a few $ more for the grenade gripped hard anno'd LX version on line.
