Looking for a replacement light
Eagles1181
Texas
Looking to replace a Fenix PD35Tac I lost a couple months ago.
Currently running a Wurkkos FC12, and I love the User Interface on this light. Problem is I don't trust the durability.
Light must run on 18650.
Anybody got any suggestions?
Location does not matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
__X__Up to $100.
__X__Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__X__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
__X__I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). **IF not super complicated, I am not real good with a soldering iron**
I want this is run on 18650. I have a ton, and am not ready to start building inventory in another size battery at the moment
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__X__I don't care
I want a very low (see without waking the wife) >5 lumen (sub 1 lumen preferred)
I want a mid range 200-500 lumen option for navigating in the woods
I want a turbo in the 1000-1500 range
I have not interest / never use blinky modes. Don't mind if it has it as long as it does not get in the way.
__X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
_X___Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__X__30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
I want the main switch to be a tail switch. I don't care if the admin switch is also on the tail, or is up front.
I want instant access to Turbo.
Instant access to moonlight / firefly would be nice as well.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
__X__IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
__X__Other ** This thing will live in my pocket.**
____"Hybrid" light (bright incandescent combined with long running LEDs)
__X__Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Kayaker530
Northern California
The Convoy S21A is worth taking a look at. Yes, it is designed for the 21700 but it will run 18650 Protected and Unprotected cells as well. It is a very versatile light with lots of programming options. There are several LED offerings. It is not rated for IP but I have taken that light and several of the Convoy Flashlights with the rubber tail switches and dropped them into my hot tub for over 2 hours without any leakage. I have bought hundreds of dollars of lights from Simon at The Convoy Flashlight store without any issues at all. I did durability testing of some of his other lights and have been very impressed.
I really like the 519A LED in 4000k myself.
ChrisGarrett
Miami, Florida
____Up to $25.
____Up to $50.
__X__Up to $100.
__X__Up to $200.
____Up to $300.
3) Format:
4) Size:
____I don't know.
6) Manufacturer:
__X__I don't care
____I don't know.
____I don't care.
____I don't know.
____None needed
____Holster
See what you can find from ZebraLight.
Chris
aznsx
Phoenix, AZ USA
I have an 'original' PD35 TAC (which had an actual TAC mode which can effectively render the side switch harmless when desired). It's had an easy life inside, but I still essentially like it.
The lights I have which have largely replaced it have all come from Streamlight. If great engineering, reliability, widely available, long term support / parts if you should need it, etc. - and at a sane price are a priority, I think you will find your perfect solution from that company - most likely in the Protac line. Also consider the simple flexibility of the Ten-Tap feature to allow you to tailor it to your preferences without using / carrying around a flow chart. There are several lights in that line that you might appreciate, so I won't try to narrow it down for you. If you want things like the Ten-Tap flexibility, Borofloat lenses, real FL1 2-meter impact ratings, etc., you'll find such things in some of the ProTacs as well, and they offer such things which are very difficult to find from other manufacturers - especially if you want most of that in one light.
Rafael Jimenez
Mexico
____Up to $25.
____Up to $50.
__X__Up to $100.
__X__Up to $200.
____Up to $300.
3) Format:
4) Size:
____I don't know.
6) Manufacturer:
__X__I don't care
____I don't know.
____I don't care.
____I don't know.
____None needed
____Holster
