Looking for some light recommendations
manfromweb
ny, usa
Hey guys, I filled out the checklist:
==================Flashlight Recommendation Checklist================ 1) How would you prefer to purchase the light?
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____Up to $300.
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I don't care
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____90-120 minutes (Runtime is moderately important, but still not critical)
____Any size switch will do.
____I don't care.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
____IPX4 (Splash resistant)
16) Storage conditions
____In house (temperature/climate controlled environment)
Any help would be much appreciated!
alpg88
there are literally hundreds of lights that would fit, however for unpaved rural area you need , imo a minimum of 1000lm, or even more, you do not have to use it all the time on high mode, but you will find them extremely useful, especially since we are talking about flood,
I personally carry noctigon kr4, I'm doing building engineering work, so i use it in many different environments, never felt it falls short, it is about 60 bucks, and runs on 18650. sold online by manufacturer. https://intl-outdoor.com/
Also convoy lights would fit your criteria, sold on ali express, by manufacturer, https://convoy.aliexpress.com/store/1100591265
