Acebeam L30vn - L16vn Companion ;-)
Skylumen
L16vn mod to run 20700
1) remove body from light.
2) Remove plastic retaining ring with needlenose pliers or large tweezer
3) Remover internal sleeve
4) Light will now hold 20700 with side switch operation only
5) If you got a Manker U12 tail cap you can now have a L16vn Shorty with some tail cap mod.
Newlumen
United States
So whats the deal with the sanyo 20700?? I know this sanyo perform almost similiar to the sony vtc6 and bigger mah..
please tell me why people like this sanyo 20700.
Kevin1322
Phoenix, Arizona
I'm confused. Why does removing a plastic retaining ring and the internal sleeve deactivate the tail switch? I ask cause I like the idea of using the 20700 but it's not worth it to me to lose the rear switch.
MAD777
White Mountains, NH, USA
So who has the SST40 edition of this L30 and can tell me if there are prominent rings in the beam?
(My SSR40 D1vn has those distracting rings, otherwise a great light).
Any comments on the size of the hot spot would be appreciated, comparing to other lights (especially S200C2vn).
Kevin1322
Phoenix, Arizona
Nothing against the light, but it does have those rings; reflector just not designed for that LED. Great light great performance otherwise though. I sold mine, but if I remember right the hot spot was about the same as the SC200C2vn with the SST40. L30vn does have 10k more lux and 250 lumens more, and a little wider spill, but that's not too noticable really. Something about the SC200C2vn that is just really special to me though. If you want a beautiful beam, then go with it.
Keitho
CO, USA
How? I'm guessing you lube up the cell and tap it into the light with a hammer...
Skylumen
Remove the internal body sleeve. The sleeeve is for the rear switch which VNX2 doesn't need anyways.
Skylumen
What is the spec on this specific build in the pic? I'm interested.
  • 70.2 6500K
  • Stock UI
  • USB charging OK
  • 21700 Battery Included
  • SDHT Bezel
  • DHT pocket clip
  • Shorty Tail Cap
I got the parts to build another if you are interested. $170
Steeldog
  • 70.2 6500K
  • Stock UI
  • USB charging OK
  • SDHT Bezel
  • DHT pocket clip
  • Shorty Tail Cap
Thanks for the breakdown. I'm going to wait for the T27vn with shorty tail cap and hopefully VNX2 UI.:thumbsup:
Steeldog
Beamshot of my Acebeam L30vn II flooder in XHP70.2, 6500K. Those little specs are ash from the Butte County fires in Northern CA. 150 miles from where I live.
