trailhunter
- Joined
- Jul 2, 2014
- Messages
- 1,095
Just measured both m43s
219b = 5000 L
219c = 5800 L
Sent from my SM-G970U using Tapatalk
219b = 5000 L
219c = 5800 L
I'm going to start modding my d18 with 18 219b's.
Almost sounds like a waste of emitters for such rare emitters but it sounds so beautiful.
Does anyone have tint comparisons between sw45 and sw45k? I have a new order of 50ct of sw45k coming
Ah I someone said sw45 and sw45k are the same emitter but clearly, the sw45k is more roseyIm glad you are using 219b, no matter how many. I love them more than 219c
Led mixing has the unexpected benefit of creating tint below the BBL
If you were to mix some 219c 3000k with 5000k it would produce 4000k w negative Duv
thanks for confirming that the 219c is 16% brighter than the 219b that you tested
you can see why Nichia needed to do that, to keep up in the lumens race
yes, the sw45k is more pink, I happen to love it
the sw45 is still much more pink than a 219c
sw45 left, sw45k right
l-r sw35, sw45, sw 45k, XM-L 6000k
sw35 left sw45 middle, sw 45k right
ps, all pictured Nichias are 9080 variants
I'm noticing a tint difference between sw45 and sw45k, i think they are different here. That supplier is just blowing smoke up your donkey.The same question i had few weeks ago toward one of the suppliers. The answer was: it's the same emitter, only thing is that someone is naming it sw45 and the other sw45k.
So relax and enjoy.
One sample of each emitter isn't enough to declare tint differences between the two, even if in the same light with the same optics. We all know there is some within emitter groups.
I hope to see new 219F HI CRI soon...
Looks like it's brighter than 219C so far and if Nichia could hit that 9080 area that would be a great upgrade in the current LED scene
PS i kinda doubt that there will ever be 9080 emitters after B
Theres the newer E21A which is R9080 and then there is the Optisolis which exceeds 9080 ratings and destroys the 219B in color rendering.
I ordered sw40s as well, where do those fall in color?
Output of the singular E21A is easily equivalent to a singular 219B. You can fit 4 E21A in the space of about 1x219B so output per size is much higher with the E21A. The reality is the whole industry is moving away from the 3535 Triple pad form factor, just how the 5050 like the XML2 was retired.Very true but output and "standard" build is not in the same basket.
