Packhorse
Rebuild with Li Ion. Its probably cheaper...until you factor in the new charger. But since you need a new charger anyway still cheaper.
Packhorse...I am sure you are right. .....
That does help. I looked at the driver but didn't see any specs other than 2.5 - 3a. So the PCB will limit the max current from the battery to the driver at 3a and will shut off at 5a to prevent discharging the battery to low. This setup will also allow the alert function to work when voltage reaches 6.For what its worth, most of my can lights use 2S packs and I drive single LED's.
