Yeah, switching is the way to go. Why waste power as heat to get a voltage that a diode can handle? Re: Maxim... yeah, I've been that route, and that's why I don't have an eval board. Plus, when you get it, it's configured for the "standard" output and you have to remove one of the microscopic resistors and find a replacement. They're about the size of deer ticks. Tiny. Definitly not the project for a home experimenter. I don't think it's something I'd want to try w/ the hand-wired techniques.
Re: the finished size. Given the proper equipment, I could make one that sits on top of an AA. With the LED.
Someone sent me an email asking for the details of the cct. (how does it work, etc.). I tried to email him back and got a "too many files open" from his mail server, so I'll post my attempt to explain it here.
Subject: Re: Step-Up Circuit....
Doug,
My best guess at the Infinity (guess, because they've started sealing the electronics, now) is that it a simple voltage doubler. The LED WILL bias "on" (er, sort of) w/ a lower voltage. Try it w/ a white LED two new Alkaline batteries... you will get SOME light output.
The circuitry I am trying to use is kind of like a charge pump, but w/ some additional "logic" and switches, rather than just a resonant circuit. Most basically, there is a clock/ square-wave generator, there is a voltage comparator, an inductor/ capacitor cct, an internal voltage reference, and a diode. When the cct turns on, the comparator checks the output voltage against the reference, and if Vout is lower, it switches current to the inductor. After the current rushes into the inductor, the cct switches the input to gnd and the inductor, trying to keep it's current state, discharges through the diode/capacitor part of the cct. The cap is across the output -- it's voltage starts to rise, and the cycle begins again. When Vout is where it's supposed to be, the comparator doesn't fire, the inductor doesn't fill, and doesn't discharge across the cap. This is done at 200 kHz or higher... the "stepping" is very small and the resulting ripple is also very small. You can get a sub-1% voltage regulation that way. Down side is, w/ the lower input voltage, the efficiency is somewhat lower, the output current can be limited, and you need to "bootstrap" the input to the output to bring Vin up. Whew. Anyway, no "doubling" or other multiples of the input voltage. Vout is independent of Vin (to a wide extent) and is dependent upon the internal Vref and a resistor network.
The proj is on hold because I don't have any of my equipment or supplies, and don't have the requisite parts to experiment further. The resistors are about the size of a deer tick, and the caps are about the size of the OLD fashioned (very tiny) chiclettes... I don't have the proper resistor values to make my only cct run at 3.6v -- it's biased at 5v.
--- Doug Ricci <
[email protected]> wrote:
> So, how does this circuit you mention > below, differ from the one in
> the Infinity? Is the LED on the Infinity > not biased fully on?
> This would make since, since the Infinity > is rather dull in brightness.
> Thanks,
> Doug
If you know what's good for YOU, vote Libertarian.
