Thanks again gents, just revisting this thread. So I was looking to get some chargers that are basic and solar compatibale and won't keep turning themselves off as per some of the concerns mentioned above.
I saw the xtra Mc1 recommended above. The literature I am reading lists the Li-on 18650 and 14500 I use but can it also be used for eneloops? Would be handy if so...
Failing that I see the Klarus K-1 looks pretty simple and lists all the Li-on and Nimh batteries, anyone know if this would handle solar reliably?
I'll probably pick up a few of whatever the best recommendation is.
No, unfortunately, the Xtar MC1 (500mA), Xtar MC1+ (500mA/1A) and Xtar MC1+ ANT (voltage meter, 500mA/1A) chargers are all only lithium-ion chargers and don't do NiMH. If you want a smaller, cheaper charger that is a single bay, does NiMH and li-ion, but only in the AA/14500 sizes, or smaller, look to the Xtar XP1 Hummingbird USB charger.
It does 250mA and 500mA, so it's good for the 14500/AA sizes, the 18350 li-ion high current cells, the 16340 size and the lowly 10440/AAA size.
You can then get an Xtar MC1+, or even ANT and use those for your 18650 size li-ions, or even smaller, although that 500mA rate is probably a tad high for 16340s and definitely too high for the 10440s, if you run those.
For about $20, you have two good chargers that work with smaller USB folding solar panels.
Since you're in Australia, look to GearBest for the Liitokala Lii 100s and/or 202s. While they both have their deficiencies, they're inexpensive, so you can buy a few of them for not a lot of cash. Their rates are both 500mA/1A, but they are true multi-chemistry, multi-voltage chargers that double as so-so power banks in a pinch. Still 500mA is a bit high for some cells, but you're covering a lot of your bases.
These chargers are cheap to own and if you pick correctly, you can have emergency charging for not a lot of money.
Chris
