alternety
I have yet to find good reviews across several brands. There is at least one thread here that extols the virtue of Tenergy. In my experience; not at all acceptable.
I bought 8 Tenergy 4 AH cells. Run time on my radio seemed short. The cells were used as 2 sets of four. They have had pretty much the same usage history. Three or four cycles I think. So I decided to do a refresh on two of my BT-C3100 chargers. I ran two refresh cycles because I did not like the results.
I forgot to note that the Tenergy are low discharge, and that is what I am looking for.
Second test, out of the eight: 4 were around 4.2AH. Quite decent. One was about 3.9. Eeh. But the rest were at 2 - 2.5AH. Not good! Each set had a mix so were being affected by the lowest common denominator. So after changing set contents, I will have one good set and one at essentially half capacity.
I saw multiple posts around just saying there &&&&&& are the very best. One post tested with a flashlight run time, but it was for AA across the brands.
I want to get either 4 or 8 cells to replace the Tenergy to get max run time on the radio.
