wbp
- Joined
- Feb 11, 2008
- Messages
- 251
I've been pondering the accuracy of our polystyrene spheres. I believe that lights that have a very small intense spot are not measured as accurately (or the same) as those with wider beams. I observe a "hot spot" on the outside of the sphere where the beam hits, and surmise that some light is getting through, and more so with more smaller beam spots.
It occurs to me that we might be able to improve this with the application of something directly opposite the input port. Perhaps a small disc of aluminum, for example, or aluminum coated by BaSo4. Seems like this would be something interesting to experiment with.
Also, if anyone is interested, I have been able to obtain service literature for the AEMC CA813 meters, and can now calibrate them. This meter claims to have "CIE Photopic" sensitivity, but like all such meters it is calibrated using an Illuminant A light source, which is a long way from our LED flashlights. Also, with any meter using a cosine receptor, the placement of the sensor is critical - this can introduce significant error during calibration. I've developed a new technique for calibrating this type of meter that yields significantly better results.
William
William
