Anders Hoveland
- Joined
- Sep 1, 2012
- Messages
- 858
I wonder if we will eventually see retrofit LED bulbs with colored filters for residential use, much like the filtered coatings already being used to modify incandescent light bulbs (such as Chromalux and Reveal). Maybe some people just do not really like the light from LED bulbs, and by filtering it the light illuminating the room could be subjectively made more pleasant.
http://www.meijer.com/assets/product_images/styles/xlarge/1001029_046677135591_A_400.jpg
Stating the obvious again, but filters may affect the color of LED light sources differently than other types of light sources. Each type of light source tends to have its own unique frequency profile, and these frequencies will uniquely match to the frequency being absorbed in the filter. It is not just about "color".
For example, neodymium glass appaears purplish under incandescent and LED light, but appears dull bluish grey under typical fluorescent lighting. The fluorescent lamp gives off discrete frequencies, and the main yellow frequency absorbed by neodymium glass is not one of those.
So some filters may result in different types of color changes depending on the type of light source. Since this thread is about LEDs, we should note that typical white LED light has deficiencies in deep red, blue-green, and violet frequencies. So filters that absorb these frequencies might not affect the LED as much. Also, because LED has a relatively narrow blue spike, there is potential for filter frequency mis-match. A filter designed to filter out blue light (and thus appear orange) might not work as well on LEDs. If the filter is filtering out multiple frequencies, the ratio of color filtering will be off.
Specifically, many red filters may significantly reduce the efficiency of LED flashlights, since LED light actually only has a limited ammount of red frequency light, and much of the light that is being perceived by red color receptors in the eye is actually orange frequency. It would be especially difficult to really get a true red color (that is not somewhat orangish) using a filter over a regular white LED flashlight.
http://www.lighting-gallery.net/gallery/albums/userpics/11216/normal_SANY3047.JPG
I suspect that a phoshor coating may actually be used in a certain type of incandescent bulb, in Osram-Sylvania's double-life halogen with "modified spectrum technology". There's something about the light from these bulbs that I just do not like. It's definitely not the same effect as neodymium glass. The outer bulb is a barely noticeable slightly pink color, so I think it might involve some type of phosphor rather than the usual colored filter coating. Very interesting. Presumably some of the violet and blue light (even some of the near ultraviolet being emitted by inner halogen capsule) is being converted to red light. The intended effect apparently was to try to lower the correlated color temperature, in an attempt to mimmic the feel or normal incandescent bulbs, while still getting the higher efficiency of the hoter halogen filement. I am speculating a little here, I really cannot find any information about what exactly this "modified spectrum technology" advertized on the packaging really is.Interesting... phosphorous filters...
