Re: Cycle Testing Observations…
First thanks for the effort, we appreciate it.
SilverFox said:
Two chargers were compared. The Energizer 15 minute charger was the fast charger, and the Sanyo NC-MQH01U was used as the slow charger by utilizing one of the slow charge slots. The Sanyo charger charges at roughly a 1.0 amp rate in that slot.....
Tom
I am bit puzzled by your terminology. I would call the 15 min charger "super-fast" and the Sanyo @ 1 / 2.5 = 0.4C a "medium speed". I thought that 0.1C (250mA) used for the forming stage is a "slow speed". Not to split hair, the reason I bring this up is that some people prefer longer cell life to 15 min convenience. For instance, I simply have a set of backup Alkiline cells for the times when I am in a rush and just don't bother with "super-fast" or even "fast" speeds.
When I got my BC900 I used the default 200mA rate - "slow". Due to the issues brought up here I switched to 500mA rate which is still "slowish" according to my terminology. My objective is to get a longer cell life.
In fact, many uses are a low to medium power draw, such as wireless mice, wall clock, MP3 players, etc. They are not as demanding as
SilverFox said:
then discharging it at 2.5 amps down to 0.8 volts.
Now I realize this method was chosen for speed, so don't suggest you test other "slower" scenarios, fair enough. My question is if there is a way to extrapolate from your tests or some other trick to derive from your tests results for this other scenario?
"Slow" (0.1C to 0.2C) charge rate and "low" power draw rate (max 0.3C)
For me at least this scenario would represent the majority of uses, hence I am more interested in it. It is especially relevant to the multitude of electronic gadgetry that doesn't have electric motors or other moving parts.
Again, not to diminish your work, it just doesn't represent most of my use scenarios. The tests seem to show that after 150-200 cycles the cells were degraded, unusable for most applications, compared to claimed 500-1000 cycles. I thought NiCd handles about 1000 cycles and NiMH handles about 300-500 cycles (might have read it at the battery university site). I wonder if the "slow/low" scenario would get much closer to the 500 figure.
As an example from real-life slow/low scenario, I have solar lights in my driveway. Each has a pair of NiCd AAs and a LED light. Clearly it is a slow charge rate as solar panel is small. I assume it is a low power draw as LED is tiny compared to reular flashlight lamps. From the original set most of them have suffered from "accidents" (lawn mower and such). The 3 remaing lights still work very well. I think they are about 3 years old, which is 3 x 365 = 1000 cycles. In fact, they survived temperature range from -30C to +30C.
Hence cells can last a very long time and even exceed specs.
Again great work on your part and I am not attacking/criticizing it. Just wondering if there is a way to estimate slow/low scenario cycle life without spending yet more time/effort.
thanks
