NiOOH,
I have been having a lot of problems with Energizer 2500s. In one high draw application they kept collapsing early, like to almost 0V. Now I removed them from that use. In a music box for my kid they seem to have developed a memory effect and had to cycle them on BC900 to bring them back.
I am using Sanyo 2500s for high draw and they are doing much better. Also, my older 2K and sub-2K cells are fairly reliable. I wonder if I should avoid 2K+ cells altogether. Seems manufacturers are sacrificing a lot of other attributes (such as cell lifespan) in order to achieve 2.5K+ capacity.
I even paid too much for Eneloops just so that I can have a reliable standby batteries I don't have to top off all the time.
I use Sanyo charger for the initial charging @1amp until they batteries warm up. Then I transfer them to BC900 @0.5amp to finish at lower rate, cooler.
Anyway 100+ cycles for 2.5amp batteries is a joke. I consider any battery that handles less than 300 cycles a failure.
Oh, and looking forward to an update; thanks Tom
P.S.: I am almost tempted to test a 2K cell on BC900 at 0.5 charge, 0.25 discharge (very slow rate based on Tom's scale
