Alex1234
Hope you guys enjoy the photos
http://www.candlepowerforums.com/vb/showthread.php?412041-DEFT-edc-X-1x18650-at-370Kcd!
can this light use 16340s ?
I'm using AW ICR123 750mah rechargeables but they don't last long on full blast. I switched back to protected 3400mah 18650 cells.
I'm using these - http://www.cpfmarketplace.com/mp/showthread.php?144427-NEW-Hi-current-Protected-R123sWhat are the ICR123 rated at? The Efests I mentioned are rated at 10.5A continuous current. These by the way are LiMn chemistry.
I got mine today and I can not get it to come on. I tried using 18650 3100Mah protected no button top cell and I also tried an 18650 3400 mah protected button top cell and it still will not come on. I put both batteries in with positive end in first towards the light end. Any ideas Please?
stingray, I'll tell your what the Saab man told me: tighten the tail cap. It may seem like you tightened it fully but it's likely not. Give it a shot.
One idea - have you tried turning the wheel right underneath the button to each of its four settings, and then pressing the button to turn the light on right after changing the setting? One setting is momentary on (full), the next is strobe, the next is minimum (a tiny fraction of a lumen that can barely be seen), and the last is full continuous.
You may have it set at the minimum setting, which can only be seen in a dark room.
