M@elstrom
Would you accept pre-payment for the Anodized P7 DHS's prior to the second week of May (to beat the rush)?
Hi,
I have received them today.
But none of them fit in my Maglites.
All of my D-Cell Maglites ( red, blue, black) have an inner diameter of exactly 34mm but the heatsink I got have 34.25mm.
But the biggest problem I have is with the C-cell Maglite. The C-Cell Heatsink measures 26.17mm and the inner diameter of my C-Cell Maglite is 28mm. Therefore the Heatsink is nearly 2mm too small???
Hi,
Hi
What about HAIII heat sink for 2Dmaglite?
If so i might just get them since its only afew buck different as i cant wait any longer :shrug:
Hi,
Some D size require sanding Mag body to fit properly. For C size is it possible you have older C Mag. I know that older D size Mag are larger and wouldn't work with DHS. I have C size Mag and inside diameter measure 26.17mm. Please check the serial number on the body, does it start with "C". Older Mag which will not work with current heatsink.
Since the body of the Mag mod will be negative does the HAIII coating reliably electrically isolate the heat sink from the Mag body? If no, is the Arctic Alumina epoxy non electrically conductive enough to isolate the LED? Thanks in advance!:candle:
- Yes the HAIII coating is electrically insulating
- Arctic Alumina is also electrically non conductive (unlike Arctic Silver epoxy which can have a capacitive effect)
Am I on the Saturday shipped list?
Which would be best for a P7? Have you tried it yet?
Sounds like a win win. I will purchase the HAIII P7 heatsink from H22A when they become available. I will use Arctic Alumina epoxy also, thanks for the quick reply.
H22A said:I use D size HAIII with both ridges removed. It works great.
