Bimmerboy
I'll probably never use the 700 lumen turbo, but wondering about sustained output on high at 400 lumens.
EDIT: I probably shouldn't have posted this here - I failed to note the sub-forum this is in. I should let FS answer their own questions - they're better at it than I am!
Edit bump: Please disregard my previous post, which was made in error:-(
To make sure we quote the accurate response, I have sent this to the Fenix engineer. I will post his answer here when I hear back. Thanks!I'll probably never use the 700 lumen turbo, but wondering about sustained output on high at 400 lumens.
Looking forward to it, and thank you!To make sure we quote the accurate response, I have sent this to the Fenix engineer. I will post his answer here when I hear back. Thanks!
Here is the response I received from the engineer. Looks like he needs more info from you:To make sure we quote the accurate response, I have sent this to the Fenix engineer. I will post his answer here when I hear back. Thanks!
I should have been more clear about that. My apologies.Here is the response I received from the engineer. Looks like he needs more info from you:
"Is the customer asking about sustained runtime on high at 400 lumens? If yes, I will double check on the testing record and get back to you next week."
Here is the answer to the last part of your question:I should have been more clear about that. My apologies.
I'm asking if there is a step down due to heat, or does it run cool enough to stay at 400 lumens?
Thank you for the reply, and your time, Fenix Store. It's much appreciate your owning a Fenix product.
