Drilling and tapping holes in a Mac's Custom EDC
jkid1911
NJ
I've given up trying to contact Mac to have a pocket clip installed on one of my Mac's Custom EDC lights so I'm going to buy a clip and drill and tap the light myself. Any advise or assistance would be greatly appreciated. I have no experience in this so thanks. I would also entertain suggestions as to who you might recommend to do this for me. Thanks again.
Mattaus
Brisbane, Australia
What material is it? The only advice I can give is measure MANY times, go slowly and always think worst case.
Sent from my Galaxy Nexus using Tapatalk
precisionworks
Benton Illinois
It can be done with only a drill press & drill press vise but it's hit or miss. The easy way to do it (at least it's easy for me) is to hold the body in a Delrin split collet & secure that in an 8" super spacer on the milling machine. Locate the clip where you want it & use a fine tipped Sharpie to mark hole locations. Spot drill, tap drill, run the tap through with a small Tapmatic head, chamfer & done.
About 45 minutes if everything goes well. If things go badly you'll need to buy a replacement body & start over. BTDT.
Setup is similar to trit slot milling:
Image-9853934-155302129-2-Web_0_bd38ad6c7dd1cd6f7f919f54d4e027e0_1
McG clip on a V10R Ti:
Image-9853934-161659975-2-Web_0_a7d22283e43a27f2d3ff7defe812e05f_1
