KeepingItLight
Re: Eneloops: what charger do I need?
As a newbie to Eneloops, I am trying to learn what I can about their care and charging. This thread is a great resource.
Initially, I thought I would use my Nitecore Digicharger D4 to charge Eneloops. It has the capability. After watching the AskMrWizard YouTube videos on NiMH batteries, however, I changed my mind. Those convinced me that I wanted a charger/analyzer.
Brief aside: The AskMrWizard vids are a great primer on NiMH. See my mini-review and links here. Part 4 presents a worthwhile system for labeling and tracking batteries as they age. I think even experienced flashaholics might enjoy that part.
At that point in my research, I learned about the Maha MH-C9000 WizardOne Charger-Analyzer. It's a design that is a little bit older than some others, but it is still well-regarded. The testimonials in this thread bear witness to that. But then, I began seeing references to the way it terminates charging of NiMH batteries. According to the review by HKJ (and also other sources), the C9000 indicates that charging is complete before it actually is. In order to get a full charge, you have to leave your batteries in the charger for another hour or two while they trickle charge to full capacity. Very odd. If you leave them on too long, then I suppose you are subject to the same problems given by cheap chargers that continue trickle charging after an Eneloop has been fully charged. Some experts, therefore, recommend that the C9000 not be used for regular charging. Instead, it should be used for discharge, break-in, cycling, and capacity testing. These are functions where it shines.
Next, I checked out the La Crosse analyzers. One of them is featured in the AskMrWizard videos. They seem fine, but when I saw the HKJ review of the much lower-priced Opus BT-C700 NiMH Charger, my focus shifted to Opus.
HKJ gives the C700 a generally positive review. It cannot, however, charge Li-ion. At first, I thought that might be a problem, but later changed my mind. In reading HKJ's reviews of the Opus models that can charge both NiMH and Li-ion, I began to sense that—for purposes of charging NiMH—the NiMH-dedicated hardware and algorithms used in the C700 are just as good, and perhaps a bit better, than those that Opus uses in its hybrid models. As I write today, I cannot remember the details, but I definitely sensed a small difference. Having separate bays for AA and AAA batteries, as the C700 does, also makes things easier.
Anyway, this newbie ordered the Opus BT-C700.
I hope that by sharing my experience, I can help others. I welcome any corrections and advice that readers can offer. I am planning to use the Opus as my primary charger for all my Eneloops.
