Well, Aus$16.99 is approximately US$13.35, so it ain't that bad. If you live on the farthest underbelly of the planet* you take what you can get...$16.99 for 4 Lithiums is VERY expensive! You can get 4 Energizer Lithiums for around $8.99.
Works out to $3.30 U.S. a cell.holy cow... $4.25 per cell?!
*Except for New Zealand, of course.
Oh, I did not check. We also have Cole's in the US eh?
Same poop, different packaging.
Buy the cheapest one.
Energizer has two different Lithium AA chemistries. The old and the new, the cheaper price will get you the older chemistry, which has a shorter shelf life and less mAh.
What Panasonic ones?The "new" cells are a cheaper alternative since Energizer's patent on AA Lithium primary cells just ran out and they now face competition from the Panasonic ones.
Actually the "Ultimate" chemistry is the "old" cells. The "new" cells are a cheaper alternative since Energizer's patent on AA Lithium primary cells just ran out and they now face competition from the Panasonic ones.
The believe the only differences between the old L91's and the "Ultimate" is a change in marketing.
... The original Lithium AA chemistry (10 yr shelf life) was updated at some time several yrs ago to give more power and a longer shelf life (15yr). No marketing was applied to this change, the batteries simply got better. I think this did coincide with a label design change though...
Here is a picture of the "old" 10yr chemistry L91 circa 2001 vs the "new" 15yr chemistry L91 circa 2006.
2009 model Advanced EA91 (old chem) and Ultimate L91 (new chem) photos can be found elsewhere or in the datasheets.
http://data.energizer.com/SearchResult.aspx
Is one model better than the others?
I just received an order of "Ultra Lithium AA e2 L91"....what would these be?
Thanks,
I don't recall the use of "ultra" in any official marketing from Energizer.
The best performance would be from recently made "ultimate" L91 batteries, which should have a use by date of 2024 printed on them. What is the date code on your batteries?
But "better" is a relative term. If I can get dtd 2022 batteries for half the price then that might be considered better.
