Loverofthelight
- Joined
- May 9, 2017
- Messages
- 74
I am guessing, xpg 3 in spot. Anyone know what bin? Bin of floods?
They probably saved $5 using the xpg over an xpl hi. Sadly.
Are the 18650s in parallel or series. If series, then a good buck driver and efficiency. I hate 3.7 volt single cell drivers. With protected 18650s, name brand, series is perfectly safe, as long as no parasite drain. Need a true off. Though the low voltage cut off should kick in. Also, I recommend monitoring cell voltage several times a week, during use, after charge and depleted. Make sure cells matched and charging is cutting off correctly.
Apparently, the toolbelt design is popular enough to keep making. I guess the subpar 3800 candela at 6.5 hours work setting, could squeeze out 8 hours with better cells. 3800 is a little dim bouncing from 1 meter to 2 meter for detail inspection, but is close enough that I would pass it.
They should have used a v5 4300kelvin xpl2 hi, not a $2 xpg for the spot.
As what I've read on Fenix official website, the 18650s charging is in parallel, while the discharging is in series. You can have a look.
