kj2
Just ordered the TK75 good price too. Hopefully it will arrive within 2-3 weeks.
I guess you ordered it from Fenix?
I, too, am thinking about this one.
As I posted in the ZL 6330 thread...
In addition to all of that, you can buy 18650 that are protected...RC lipos have no such protection. I just did a CPF search and a Google search for "18650 fire" and can not find a single report of 18650's catching fire in a flashlight. Not to say that it hasn't happened, but definately being blown out of proportion IMO.
So if the batteries are all in parallel and have over voltage protection what would keep me from taking a hobby charger to the battery holder and charging the whole thing at 4 Amps? (1 amp per battery that should get distributed since it's a parallel circuit. )
Says early December for us in the uk, not a bad price either:
http://www.ledfiretorches.co.uk/fenix-tk75.html
Certainly, when it comes to the batteries in the extender tube, those batteries can't be in parallel with those in the main body? Or am I misunderstanding things as usual?
I would continue to charge 18650's individually since there would be no way to monitor each cell. RC lipos have "balance tabs" that allow the chargers to monitor the individual cells. That way if one is taking a charge faster than the others, the charger can slow, or stop the charge, or even drain an idividual cell before something catastrohic happens.So if the batteries are all in parallel and have over voltage protection what would keep me from taking a hobby charger to the battery holder and charging the whole thing at 4 Amps? (1 amp per battery that should get distributed since it's a parallel circuit. )
The carrier might be setup in a series-parallel configuration {2 banks of 2-18650's for 8.4vdc max} That's why it can also be run on just 2 18650's. This will give you 5200mAh off of 4 Fenix 18650 batteries. This makes sense on the spproximate 1 hour of run time on turbo. 5.2 total amperage drawn divided by 3 = 1.4 amps each led. So if this is true, don't hook up a hobby charger to the holder. You would be charging two banks of 2 18650's in series. Hooking up extensions just parallels the same voltage for added runtime. If it is setup in an all parallel configuration, that would be 10400 mAh total. 10.4 amps divided by 3 = 3.47 amps per led drawn.
That is exactly what you'll have to do!
