Jash
There is no such thing as too much light. All other opinions are invalid.
With weapons, you might have a point. I don't know too many people who think bigger and better nukes are a good idea.
But flashlights...no freakin' way. Maybe when we can exceed sunlight intensity over a large area, we can have this discussion again, but for now they are not even close to dangerous brightness with proper use. I agree that people can misuse high-lumen lights, but that is hardly anything new, and certainly is no reason to halt progress.
You have to remember that progress isn't a pick-and-choose type deal. If you research one thing, it might lead to a breakthrough somewhere else. Also, one person's awesome new feature might be a headache for someone else. But that is the beauty of the market...as lights develop, we just get more and more choices, and we can each find the lights that tick all of OUR boxes. Even if I agreed that we should limit one criteria, in practice that can't be done without harming every other aspect. Thermal and electrical efficiency, brightness, intensity, compactness etc are all related, and holding back in one area will at the minimum slow progress in the other areas, and at worst lead to a general stagnation in the entire market.
It really does seem (to me) to be backwards thinking to try to limit progress. First and foremost, it doesn't work very well. If you don't like the way things are developing, just vote with your dollars, and just don't buy anything that doesn't suit you. But personally I think it is a wonderful thing that things are constantly evolving.
a 100 Watt incandescent light-bulb is about 1800 lumens. Heard anybody say 100 watt bulbs are too bright?
Yeah, my wife all the time actually... lol.. they are pretty bright for normal use. At least for us.
"Thats too much bacon".... now that... I have never heard..
I see your point, to an extent. Small single cell lights that can put out a crazy amount of lumens for only a minute or so before they overheat are trying to push out more than what they're capable of handling. But, IMO, a multi-cell light that can handle the 1000+ lumens without overheating isn't too bright. Just maybe too bright for what you need a light for.
It will get to the point where lights become licensed, or at least restrictions will be imposed like the 5mW limit for lasers.QUOTE]
let's hope not, the unenlightened masses are largely unaware of this most rewardng and wholesome hobby or avocation
Imagine hearing the often cited phrases such as:
"No legitimate sporting use" for such a light?
"Why would anyone except the police of military need such an extreme light?"
Perhaps a limit on electrcal storage devices such as batteries, limiting capacity, restricting those "high capacity batteries"? perhaps banning 3000mAh capacity 18650 cells allowing say 900 mAh instead?!
then......amid the spreading panic of total darkness without low voltage direct current storage devices.. run to the megastore only to find empty shelves ......a barren empty space where the "Energizer bunny" once resided...:shakehead
oh no! no more AA cells in stock at the store?? not available online either?!.....
a limit on the amount of batteres bought per day?!yipe!
I'm happy with warm or neutral tnts and 850 lumens on a single cell. a couple years 2 18650s could get 1000 lumens now I see 3500-5000 lumens!
Personally Id like a little more power (over 1000 lumens) on a 18650 single cell.
Damn MY wife says its too much bacon.
Its not really like that. (The over heating part...) Most of the thermal step downs are so you can have the same concept as a car with nitrous injection.
IE: They COULD make the light dimmer from the get go...and, as such, would be able to run at that dimmer brightness as long as required. OR - They could make a light that COULD be a lot brighter if needed for bursts of 5-20 minutes or so, depending upon HOW much extra brightness the burst would supply.
So, for example you have say, the option of a light that maxes out at 400 lumens, but can run at 400 L for 120 minutes....or one that can run at 400 L for 120 minutes AND be able to ALSO be able to give you a 800 L boosted beam for ~ 5 minutes at a time....and then step down to 400 L again.
Obviously, you don't have to select TURBO unless you NEED it. You could leave it at 400 L the entire time if you wanted to, or, if you thought you heard a bear a bit further away than the light was reaching...you could hit turbo to see WTF made that noise out there.
If you SEE a bear, you might want to SPRINT to the nearest tree to escape it...DESPITE the fact that you can only SPRINT for maybe a 100 - 200 yards or so, before you'd need to slow down and catch your breath. You might appreciate a burst of extra speed when needed, despite not being able to maintain it for miles.
