Flat top vs button top - difference
ank
Suppose we have 2 batteries with the same specs, except one is flat top and one is button top. Will there be any differences between them, except the physical dimensions?
HKJ
Copenhagen, Denmark
The button top will a slightly (maximum a few milliohm) higher internal resistance, i.e. it is not as good at high current. This is a very minor difference and is probably only interesting if you are drawing above 10A.
Timothybil
The great state of Misery (Missouri)
From the practical side, unless you are dealing with a high draw light like HKJ says, most button top cells are protected, while as a general rule flat top cells are not. A protected cell is one that has had a small printed circuit board added that will 'shut off' the cell if it is subjected to a too large charging voltage, too large of a current draw (usually around three amps), or if the cell gets to hot, which usually signifies internal problems. Some protection circuits will also shut off if the voltage from the cell drops to low, to protect it from damage. Usually the specifications for the cell will specify the cutoff current and low voltage cutoff point. And yes, all this protection comes at a price, since no circuit does its duty without an energy input. But the overhead of the protection circuit is small enough that for all practical purposes it doesn't exist, and whatever overhead the circuit adds is considered minor in relation to the protection its existence gives to the cell.
Oh, and most modern chargers are capable of detecting a tripped protection circuit and resetting it as part of the charging process.
Gauss163
USA
[...] A protected cell is one that has had a small printed circuit board added that will 'shut off' the cell if it is subjected to a too large charging voltage, too large of a current draw (usually around three amps), or if the cell gets to hot, which usually signifies internal problems. Some protection circuits will also shut off if the voltage from the cell drops to low, to protect it from damage [...]
Single-cell protection circuits rarely provide over-temperature protection. Almost all protection circuits do provide undervoltage (overdischarge) protection.
