archimedes
Warm XHP-50 ordered, thanks
Sold, or built ?Off to a great start, 9 engines so far.
Although it will probably be obvious during installation, does the optic fit under the lens, or does it replace the A3 lens ?
EDIT - Never mind, I went back to the original build thread and see that the lens is retained over the new optic. Thanks !
One more thing I just realized. Originally one of the tints listed for XHP was 4000K 5D2, but its actually 4000k 5B for that emitter. It is changed on the site now, but not before a couple orders were placed. If this is a huge thorn in anyone side shoot me a PM and I will see if I can come up with anything else. Thanks again all..
Apparently, there is still room for the o-ring too to provide a water-resistant seal. I'm assuming that this can either be fitted between the optic and the glass window or after the glass window but before the retaining ring but I'm not sure which way round? Maybe Matt can confirm this?
I just remembered that you had asked about this. I did try the o ring, but to me it doesnt seem to help much. The lens will still sit on it, but I think after a while it might squish into the gap between the optic and the wall. The shelf where the ring sits is angled kind of down ward.
Thanks again
Could the o-ring be placed between the glass window and the bezel ring using the tightened bezel ring to keep it in place?
