notoobright
- Joined
- Sep 28, 2015
- Messages
- 3
I'm looking for a flashlight that is
top priority requirements:
USB-C rechargeable without taking out the battery
user replaceable 18650 battery
one click on/off that does NOT cycle through different brightness or modes. I should be able to click once to turn it off, and click another time to return to the same brightness before I turn it off.
only one brightness level, or multiple brightness level but is controlled by a second switch so that I can still turn on/off the flashlight with one click
secondary requirements (nice to have but not critical)
no parasitic drain when off
has multiple brightness level, as long as it does not affect the one click on/off
can zoom in/out
What would be even better is in addition to recommending the light, tell me which web site has a buying guide that can help me find the right flashlight on my own for future reference.
either mail order or from local stores but local stores have such limited selection I don't think it would work
2) Budget: An easy question, but you may change your mind after answering the rest!
I assume something like this can be found for $50 or less. But I don't have a rigid budget.
3) Format:
handheld traditional shape flashlight.
4) Size:
Small to medium, though probably dictated by 18650 battery requirement. Not critical
5) Emitter/Light source:
LED. Color temp white, which I also think is the most efficient color.
6) Manufacturer:
don't care, just be a reputable manufacturer that will be around to honor warranty should the need arise
18650, because they are commonly available and I already have other devices that use this battery
USB-C rechargeable
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
I want a light to look for stuff under the bed, in a dark cabinet, etc If the light has multiple brightness level, then having brighter modes would be extra bonus.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
Probably one of the above. I use it to look for stuff in dark places (e.g. search for item in a drawer in the dark).
most often within 2 feet
Given the 18650 battery and brightness requirement. I expect it to be way more than 10 minutes.
____Not Important (A "night-stand" light).
Any type of switch is ok. But it must be an on/off switch that doesn't not require clicking more than once to turn on to the desired brightness.
____A simple on-off with only one output level is fine for me.
A second switch that controls multiple brightness level would be welcome bonus.
14)Material/Finish/Coating
don't care
15) Water resistance
don't care
16) Storage conditions
____In house (temperature/climate controlled environment)
can zoom in/out
3) Format:
4) Size:
6) Manufacturer:
USB-C rechargeable
don't care
don't care
