Are alkalines OK in AA 325 rotary?
Yes, but don't expect maximum output for all that long. It will drop several levels quite early on. Altogether the runtime will probably be longer than on NiMh, but only due to a lacklustre performance.
Ah, so not constant current regulation?
Lithium primary AA better?
I think it's hard to beat a couple of NiMH, especially Eneloop Pro. I most likely won't get the AA compartment, but if I do get one it will definitely eat only Eneloop Pro for breakfast, lunch, and dinner.Lithium primary AA better?
A real quality NiMH charger is too expensive.I think it's hard to beat a couple of NiMH, especially Eneloop Pro. I most likely won't get the AA compartment, but if I do get one it will definitely eat only Eneloop Pro for breakfast, lunch, and dinner.
Definitely cheaper in the long run compared to running Lithium AA. At least a cheap charger is better than nothing. Trust me, you don't really need very good charger for this. NiMH has been around for decades and most chargers available in the market are pretty capable to do a good charge. Better ones allow you to condition your batteries as well as do soft charging so it doesn't heat up the batteries too fast and too hot. Personally I use a Maha charger for charging 8 pieces in a go. Buy the cheap ones first and maybe progress to better ones later? Not sure if this will make more sense for you?A real quality NiMH charger is too expensive.
I have one but it gets hot. I do not like that so no NiMH for me. I already have a bunch of li AA
I couldn't find any Maha for $35 or I would have purchased it. Prices I saw were very high so I gave up.
I'll see what I can find. Thanks.May want to give this one a try for $36 this is what I use, no heat batteries stay cool also and let's you select desired charging current. It also offers refresh cycles and capacity test cycles.
Some of the reviews say it catches fire. 8% of the Maha reviews say it melts and smokes. Thanks for the info but I cannot take a 5% chance I will burn my house down.
