Enlightening observations about my Rotary dial, and the merits of Strobe for a pedestrian crossing busy streets.
Because I find the hops between levels disconcertingly stroby, I use my Rotary the same way I use my clicky. That is, I use all 4 presets, not just the dial. I also like knowing how many lumens I am using, so I like using presets that I have measured on my light meter. I also have a personal preference for cigar grip, and this works well with clicky commands, and makes it easy for me to aim the light at my feet with my arm hanging naturally by my side.
My Rotary dial is usually set to turn on to minimum, double click is set to 20 lumens, triple to strobe and press to Max.
Occasionally I want my turn on Preset to be brighter than minimum so I have a tendency to close my eyes and spin the dial, then reopen my eyes to see if Im close, then I ramp slowly, one step at a time.
In the course of my Rotary Enlightenment, I have developed a couple baseline references.
Spin the dial to 50% rotation, gives about 2 lumens.
I find this useful at times when Minimum is too low and 20 lumens is more than needed. I use the set screw as a reference mark so I know when the dial is at 50% or 75%. I have also developed muscle memory to spin the dial to 50% and 75%.
Spin the dial to 75%, this gives about 20 lumens.
here is a chart of HDS levels, you can see level 12 out of 24 is about 2 lumens, and level 18 out of 24 is about 20 lumens depending on which model you have..
These two reference points have made the Rotary dial much more user friendly for me. I seldom need to use the settings between the first 50% of the dial. For my needs dial all the way down for .02, dial to. 50% for 2 lumens, double click for 20 lumens, or a couple clicks past 75% rotation for 40 lumens, plus the occasional Maximum, are sufficient for most tasks. I reserve the use of triple click for strobe, when crossing the street, day or night.
I find strobe very useful, and I have even had pretty women smile at me when I do that. No one has been offended, probably because I strobe the ground, not their face. I find it very gratifying that cars come to a complete stop when I am in a crosswalk. I think they like it when I use strobe to cross the street.
Strobe gives drivers a clear visual signal, and a legitimate reason to come to a full stop for a pedestrian.
