How hot is the reflector getting? It looks like a ceramic pottery type thing that might hold onto a lot of heat.
The reflector actually does quite well. Barely warms up. I sometimes have a small fan mounted on the back of the reflector blow air over a special ducting system which blows air onto the reflector but barely blows on the bulb itself, if the outdoor temperature is warm out. Surprisingly the entire lower portion of the 400 watt bulb stays cool to the touch for the whole session, the upper portion just gets a little hot, like a car hood on a sunny day. The reflector bounces most of the in-fared heat out in the beam itself, I like standing in the beam on a cool night, for warmth. Sometimes the reflector portion closest to the bulb and directly above, gets a little warm, maybe a hundred degrees, when the fan is turned off.
Any excess heat has to go through: the Chrome tape reflector, next a thin layer of
dry wall joint compound then a layer of fiberglass, more
dry wall joint compound next 2 inches of rigid foam insulation (the frame for the whole reflector), and another layer of
dry wall joint compound and of course a protective paint layer on each layer of
dry wall joint compound.
I need to slightly strengthen the light bulb support system to keep the bulb from vibrating and wiggling around, (I recently added an electrically insulated 'soft' bulb top support system. This seems to work well. Though not too surprisingly, the focus of this big bulb is not too precise or critical; unlike the 100 watt small arc bulb which is very precise.
I should be putting some photos up here in a few moments.
Original 100 watt beam is thinner
because of smaller arc size.
Compare 100 watt HID original 24 inch LightSward upper photo to 400 watt lower photo. The 35 watt Cyclops beam to viewer's right in both photos for rough comparison.
400 watt beam on our left, 35 watt beam to viewer's right
New 400 watt beam is thicker because of the larger arc.
On our right, bright 400 watt 24 inch LightSward on left 35 watt 7 inch Cyclops
