I know this will shock everyone who knows me, I bought a streamlight product!
rwolfenstein
I got the Streamlight Protac 1L-1AA. I found that it was a really neat design that can run on 1 CR123a or 1 AA in either Alky or Lithium. I like dual fuel lights and this fit my nice pocket junk category. That way I always have a little light to get tasks done.
aznsx
Phoenix, AZ USA
Good on ya! I don't think that's one you could possibly regret - or most anyone else I know for that matter. Also, if you want the extra kick that 3 volts provides, without the downsides of CR123A, you can use LFP123s like I have in mine right now. Less run time, but low operating cost, and I can always leave home with a 'fresh one' (known quantity) without dealing with half-used (and expensive) primaries. If I had to pick a 'no brainer' flashlight to recommend to or buy for most anyone, I would pick that one.
  • Like
Reactions: xxo
rwolfenstein
I never know what might be able to handle rechargeable cells. Problem is most manufactures dont put out enough information on it. I saw this light can handle CR123a, AA Alkys and AA Lithiums. It doesnt say dont use rechargeable cells, but it also provides no information on what I can get away with.
aznsx
Phoenix, AZ USA
Well, that makes you smarter than many people then. I'm not one of those (many) who tries crazy, foolish things like putting 3.7/4.2V cells into a 1.5V light. That's because I know better, technically. You're right to be cautious, but you can trust me on this one, I assure you. Fifty years in electronics has taught me that trial-and-error is not generally a sound approach in that field.:)
EDIT: Just to clarify, do NOT use 3.7/4.2V 16340 cells in that light. Second Edit: add 14500 to that prohibition.
xxo
3.2V LiFePo4's are OK for this light, but runtime is short and you need a special charger.
Keep Power makes a 3.0V USB charging 16340 that works real well in the 1L-1AA, though it is a little too long for most multicell lights.
I like Eneloop or Fujiloop pros for my 1L-1AA when I use it as a lantern (lower lumens but much longer run times).
BTW, the 1L-1AA also runs on AAA's if need be.
aznsx
Phoenix, AZ USA
Which mfgr LFP123 are you using (SF) ?
I've been using K2 Energy LFP123A cells for >5 years now with good results. I believe K2 sort of specializes in LFP. They're not that widely available, so I'll mention that they appear to be in stock at batteriesinaflash, where I have purchased them previously. K2 has a proper data sheet for them, which I had K2 send to me. I tried unsuccessfully to attach it here, but failed (it's .pdf format), but I just did a crummy screenshot of it and will try attaching that below. If that doesn't work &/or you'd like the proper file, PM an address to me and I'll gladly shoot that file over to you. I also use these in other EDIT: LED lights (besides the 1L1AA) which are designed specifically for 1xCR123A cells. As stated, I use them in the 1L1AA because it provides far better output (per SL specifications) w/3V than w/1.5V, so why not?
I have some others from Tenergy, but have never used them because I'm not crazy about their stuff, and also can find no proper specs for them, so when I found the K2s after I ordered those, the Tenergys stayed in the wrapper unused. They might be OK, but I believe they are of lower capacity as I recall (besides lacking complete specs). I'll test them some time when I get around to it just to see how they work in case the K2s become unavailable at some point.
For the average bear I might suggest the SF cells, although I've never used them and don't have good specs for them either. They're probably more widely available (and like K2 have an available 2-slot charger for those who need that), and what they do have is a very well-known, established, and highly respected name on the label (which has value also), and I'm sure SF did proper due diligence and qualification of them before putting their good name on them. They have a lower capacity rating than the K2s, but I'm fairly confident they would work well, and would likely buy them myself if I needed more and couldn't get the K2s.
bykfixer
Dust in the Wind
The ProTac 1L AA was a wonderful invention at the time. The ability to adjust from a aa to 123 was simple genious.
I mostly use a aa with mine and ten tapped it to start on low. A nice useable general purpose output with ability to greatly increase output with a half press, or even more by swapping out the battery to a CR123. Kinda like having ability to swap motors in my car from a gas sipper to an F1 car.
No issues with the tailcap slightly loosening causing no power to the light. Streamlight products used to come with small o'rings that allowed that. But they seemed to include larger girth o'rings anymore. If it becomes an issue a wrap or two with plumber tape helps. Either that or a sliver of alluminum foil around the threads but that prevents a lock out feature where loosening the tailcap some cuts the circuit.
vicv
Southern Ontario
Thread bump but this light is a great way to use the rest of the capacity in cr123a cells from an a2 aviator. It leaves 25% of the capacity in them. I hate to throw them away. So this light gets them. Still brighter than on a fresh AA, and still a pretty decent runtime, especially on low, which is the mode I use most
sween1911
Pennsylvania
I love that light, I bought one for a business trip a couple years ago.
Love the dual-fuel AA ability, love the "ten-tap" ability to make it single mode light if needed.
Bought one for my daughter too.
Monocrom
NYC
If I could only keep one of my Streamlight models, it would be that one. Like, easily. No contest. Not even close.
aznsx
Phoenix, AZ USA
+1.
Well, my latest Strion DS HL would make me stop and think now, so I might have a brief argument with myself, but the 1L-1AA might still win (the Strion won't fit in a pocket as well). It would also win if I were recommending 'one' light to most anyone in the general population - no question. I'm certain anyone I might hand one to in the gen pop would love it.
EDIT: Of course the little Protac can live on a more diverse diet, so that's worth a lot!
vicv
Southern Ontario
Ya they're great. But you'd really need to convince me to drop my polystinger. It's always 100% charged. It throws so well for its modest output. It doesn't sap heat from your hand in the winter. I feel the polystinger is the perfect house light. Definitely not edc, but you hear something out in your yard, it's the first led light I would grab. If my souped up incan maglite didn't exist 😁
ilikeguns40
Western PA
I'm a streamlight fan, I own several non usb microstreams that I have stored in vehicles and drawers. This protac AA has caught my attention numerous times but still never bought one, now I may have to.
Monocrom
NYC
Best single 1AA light I own. And, best 1xCR123A light I own.... both at the same time.
aznsx
Phoenix, AZ USA
You owe it to yourself.
Guess you know it comes with a Borofloat lens, Ten-Tap, and a real FL1 2-meter impact rating too, I guess....all for <$50 all in. I waited a good while to buy one too. One of my many mistakes;-)
Gloomy_Antelope_4514
alabama
Hi, Im having a problem with my Strion LED HL and im hoping someone may have ran into this problem and can help. The batteries will charge fine on the charger in the side station and in the flashlight itself however the light will not turn on and i do have a brand new spare button for it and that did not help i checked the batteries with a DVOM and they are fully charged. I have taken the light all the way apart and have found no problem when i put the light in the charger i can turn it off and on with now problems it works just fine. I have been using streamlights for 20 years and have other problems but never have seen this one. Any advice or help would be appreciated.
Thank you
