Klarus Mi1C - 600Lumens Smallest Side Switch EDC Flashlight Release!!!
klight
Yes that's what I discovered after much fumbling.
My current main EDC is a 1x14500 Klarus Mi7 Ti which has the same U.I. with the exception that when the light is in lock out mode if you push the switch nothing happens. All the rest is the same and this creates some confusion when alternating the Mi7 and the Mi1C. The two flashes when you attempt to switch on a locked out light are to be considered an improvement IMO because there's another more usual reason for the light to do nothing: a flat cell.
So some kind of reaction tells you that the power is available but only on request.
Hello, Kilovolt, that's correct, if don't use klarus standard battery for the Mi1C, then will be different brightness & runtime, and no battery indicating function, thanks.
