WalkIntoTheLight
I highly doubt they still have 75% life left if they were kept fully charged most of their life. You'd be lucky to still have 75% even in the best possible conditions.
5 of 6 cells measure about 1800mAh, 1 cell about 1600mAh. They were originally 2200mAh. Samsung 22F. I think they're 10 years old, but I could be wrong... might be closer to 9. I bought it sometime late last decade.
The HP laptop was popping up a warning to replace the battery during its last couple of years. The run-time was way down, probably less than half. That is why I was surprised that the individual cells measured so high.
Maybe HP warns about the battery and reduces output after a certain number of years? Or maybe it was something else, other than capacity.
Keep in mind that the industry standard definition of "end of life" is the point when the cell degrades to 80% of nominal capacity. Most studies don't consider what happens after that point.
Yes, that's what I'm wondering about. Perhaps degradation slows way down after the first 20%.
20% degradation in one year can certainly occur in poorly managed cells, e.g. that's exactly what happened in said Dell laptops (whose batteries were kept close to fully charged by the laptop and often at elevated temperatures - both of which greatly accelerate degradation).
Yes, I know the heat + full charge state in laptops are about the roughest you can do to lithium-ion batteries. I've generally had pretty-good luck with laptop batteries, though. They definitely drop their run-time, but I've never had one get so bad it's unusable. Maybe I don't run them that hot, since I usually just use laptops for Internet browsing.
