iamlucky13
- Joined
- Oct 11, 2016
- Messages
- 1,139
Fair points. Personally, I go with 3.75v for storage, which is about 50% for the common high-drain 18650 cells. Though, I doubt 3.9v is a lot worse. It seems the consensus is that most of degradation occurs when cells are kept above 4.1v. And/or stored in warm conditions.
3.9V actually looks like it would be a lot worse. The link to a prior discussion Gauss163 posted above is handy, since Overclocker posted an excerpt of the graphs from the research paper, which I'll copy here.
If you look at the graph for 25 Celsius (room temperature) for the NMC (INR) chemistry, for example, you can see the capacity loss nearly doubles going from 60% SoC to 70% SoC. Outside that range, the trend is much flatter.
The NCA chemistry showed similar trend for capacity loss, although the plateau point looks like it might be closer to 55% SoC.
Extrapolating from that for an NMC cell, the shelf life expectancy to 70% of original capacity is 6 years at 70% SoC, versus almost 10 years at 60% Soc.
So if your strategy is 50% SoC for storage, that looks good. I'm not sure 3.75V is below that 60% level for all cells on the market currently, but HKJ's data should be a good reference source for that question.
