:sick2:......:sigh:
I'm getting real impatient ........................
Waiting for the LF-5 to come to market.
Any-one know whats causing the Loooooooong delay ??
The machine shop messed up the whole batch of tubes again and again! Oops...
:sick2:......:sigh:
I seem to notice that if I am using it at 50% and turn it off sometimes it will not turn back on unless I put in a new battery. Maybe the battery is just at the point that it has enough power to keep running but not start back up at that level?
If so it is something to keep in mind that you can't use the remaining charge of that battery at a lower output unless you have a spare battery to get it running again then change to a lower power setting. Anyone else have this happen?
Only a short question:
In the standard mode P1 is 15 %, what is P2 100%?
Thanks
Hmm...that sounds strange. If the battery is that low, it should still start back up, then flash quickly 12 times and shut off. In any case, long before that, you should've seen the 3 flashes every 40 seconds signaling a low battery. Maybe try a different battery just to see what happens?
Just received my LF2 SSC in the mail today. I love this thing!
It did take me a couple of minutes to figure out the UI, but it's pretty simple once you figure out that you can just press instead of having to twist.
It totally satisfies the geek in me
There is a thread, started by zz6557, on the LiteFlux LF2 with more photos by NetKidz and antc_tw2002 in the CPF LED section.
http://www.candlepowerforums.com/vb...ad.php?t=150055
and an informative mini review thread by NetKidz, with more photos by ynda.
http://www.candlepowerforums.com/vb...ad.php?t=154068
Another question, I'm still not clear on User Adjusted mode (UAM). Is UAM programmable and does it have both a P1 and P2 intensity? I'm trying to set Standard Mode (SM) and UAM to have different intensities so I have 4 levels of light with minimal twisting. Is this possible or is 3 the best I'll get since UAM P1 and P2 are the same intensity at the default setting?-LT
