ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
Lumapower, F1(R Bin) and SSC-P4 F1
I just this from Lumapower, Lumacraft series Formula 1.
Specfications from Lumapower Website.
¡¡LUMAPOWER Lumacraft Series - Formula One £¨F1£©
¡¡Most Up-To-Date Circuit boost to 400mA with 1.5V Dry Cell
¡¡All New Design¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Unit Price £ºUSD 50
* Integrate with LUXEON 1W R-BIN LED as light source, providing High-output and stability (LED can last for 100,000 hrs£©
* 3D Dual-Layer torch body.
* Alumium reflector and inner body for best heat and electrical conduction.
* Direct battery contact without and coil and spring which increasing circuit efficiency and provide longer battery life.
* AA-size battery compartment can fit with 1.2V NiMH to 3.7V Li-ion (incluing 1.5V dry-cell)
* Upto 40 lumens output for most advance user.
* Last for 120 minutes at High-output (50% to 100%), useful output upto 240 minutes.
* Wide range for input voltage from 0.8V to 4V
* 8.6cm (L) x 2.1cm (D)¡£
* Net weight 35g£¨not including battery£©
* Screw-turn design to minize torch length
* Torch can standing upright
http://www.lumapower.com/F1.html
Warning label came on box.
Top, Lumacraft Series Formula 1. Bottom, Fenix L1P
Left, Lumacraft Series Formula 1. Right, Fenix L1P
Left, Lumacraft Series Formula 1. Right, Fenix L1P @ 6.5"
Left, Lumacraft Series Formula 1. Right, Fenix L1P @ 38"
Left, Lumacraft Series Formula 1. Right, Fenix L1P @ 64"
The Fenix L1P is running a SXOH emitter. The beam tint has a slight green tint to it.
The Lumacraft Series Formula 1 has a very white tint. I really like the orange peel reflector, (makes a nice smooth beam). Has a twist switch. The twist action is very smooth.
The machining is excellent. Fit and finish is also excellent.
Both lights are running freshly charged Duracell Rechargeable 2650 mAH nimh batteries.
Shipping took 9 days to Southern California.
