Lumintop FW21vn Pro - 21700 Compact Powerhouse R
Patriot
Arizona
I'll be curious if there was any optics that will fit this light for a quad w2 or w1.2.
The d4svn seems to be of same size.....even if the numbers are identical, I still think it's a totally different light. It's just feels much lighter and smaller because of the body.
I agree. It's a little smoother, skinnier, and of course, has a tail switch. Still, I have a D4S Supercharged, so I'll be holding out for the single.
mt62092
canton mi
He posted the numbers on the sky lumen website I am disappointed was hoping for more throw.
Skylumen
We have 3 tiny OP reflector pushing 20Kcd each is actually an impressive feet IMO. There are single LED lights with much bigger reflector that doesn't push 60Kcd and Definitely not close to 9000L. I guess 100Kcd and 12,000L would be much nicer rounded numbers we can dream for but asking a single 40T to do that is not yet feasible.
  • FW21vn 50.2 6500K @2: 9350L, 33Kcd, 363m
  • FW21vn SST40 HD 5000K @2: 5550L, 43Kcd, 415m
  • FW21vn SST40 HD 6500K @2: 6000L, 48Kcd, 438m
  • FW21vn SBT90 De-Lens @2s: 8700L, 60Kcd, 490m
SKV89
I guess the reason why people don't find 8700L, 60kcd very impressive is because the existence of the MT07vn: White 2 5400K Max Turn On Perf: 7700L, 115Kcd, 678m
b8llzblue
9000 lumens and 60 kcd is not bad. I would have guessed 75 kcd. I still think if you can put a d4s reflector in there, that would be my fav option. 4x w2.1 for 4400 lumens and 100 kcd.
Or when they come out with the single reflector, a single sbt 90 will do similar performance. I wonder which of the two would create less heat.
richbuff
Prescott Az
I gave the other light that you mention much thought, but it is 41% heavier without battery than this light, without battery. The 26650 cell vs the 21700 cell weight will make the other light that much heavier than this light. But, on 47th thought, it would be nice to add to my collection.
The more I compare specs of different lights, the more I think about needing a turn on, two second and 30 second lumen and throw spec converter. :)
Patriot
Arizona
Originally Posted by Zunkted
I would of picked up one of these if it a was single emitter smooth reflector!
Originally Posted by vinhnguyen54
It will come ;-)
mt62092, thank you and yes, I'm aware of the output of the triple SBT90 however, it seems I may have been the only person who was waiting for a single emitter, single reflector FW21vn, based on the comments that I've quoted, yet again with emphasis in red this time.
With regards to the triple SBT90, the throw is actually slightly higher that what I would have expected. The fact that this light can hit 60Kcd with three, small, OP reflectors is a testament to the magic of this emitter. The lumen output is a little less than I expected but I can understand it based on a single cell's limited ability to deliver enough current to three SBT90's.
I was expecting a FW21vn single emitter, single reflector putting out 4500L and somewhere north of 150Kcd, again based on the thread discussion. In any case, the triple is a great light but I was looking for a thrower that beat the other 39-40mm head lights.
b8llzblue
If you like high output throw wait for the Sky Lumen exclusive KR1vn with SBT90 coming soon ;-)
That's exciting. Looks like they didn't change the protruding clip issue. I'm kinda spectacle that the sbt90 will throw better than the d4svn. The reason so is because emisar has a Olson version on this kr1 and its only doing 100kcd. How is the d4s with tir reflector doin 115 kcd with w2? It's same size head. I wonder which route will be cheaper as well? Plus I also like the fact that the pro21vn uses a 21700. If a pro21vn with a d4svn quad tir reflector with w2's is cheaper or similar price, I think I would choose that route. I guess we just have to wait and see what the numbers are to this kr1vn90
Patriot
Arizona
Unless they do something bizarre with the reflector, this is why the kr1vn90 will out throw the D4Svn...
D4Svn White2 5400K Supercharged 5000L, 118Kcd, 697m (39mm head)
G25C2vn SBT90 G2 5700K 3500L 120Kcd, 693m (39.5mm head)
G25C2vn SBT90 G2 5700K Delens 3700L 130Kcd, 721m (39.5mm head)
Olight Pro Xvn90 DeLens 4100L 135Kcd, 735m (39mm head)
L16vn90 4000L, 140Kcd, 748m (40mm head)
L16vn90 DeLens 4200L 150Kcd or higher (estimated) (40mm head)
Th558
What changes were made to increase the output of the XHP50.2?
DHart
Sonoran Desert ~ Scottsdale, AZ
I have a stock FW21 Pro (NOT Wayne's vn version). Does anyone know what the color temp is with the XHP50.2 emitters in this? 5000k? Or 6500k?
The color temp is ok for me, but my only quibble with the XHP50.2 is the green corona around the hotspot is a little irksome, though it isn't terribly bothersome - generally only noticeable when white wall hunting. But I do appreciate minor improvements, when I can get them.
Is there another emitter option, to mod this light with, to get rid of the green corona, but still retain reasonably high, cool white, lumen levels? Would XP-L emitters work well in place of the XHP50.2 emitters?
I don't care if I can't hit 10,000 lumens on turbo. For the most part, I would use the light within the ramp range, only using turbo very briefly on occasion.
