Evening all
First post here..
Paul in UK, Im assuming most of you are in the US ..??
So i have a x4 D Cell Maglight.
And its been in the cupboard for a while.. quite a while well actually a dammn long while.
6 Years to be exact..! In point of fact id totally forgotten about it.
So when i eventually dug it out, yes the batteries are not only flat they have exploded inside and turned their inards to somting resemeling partially dry clay..
Im under no illusions its probably toast, but i like to try with these things first. After all with covid hanging around us all a little light entertainment is well received.
Battery One.Pull tequnique via a coach bolt and block of wood...
FAIL battery innards to far gone to support the pressure needed for extraction. Barttery drilled out and its case fused to the aluminum hammered away with a screwdriver.
Battery Two. Pull tequnique via a coach bolt and block of wood...
SUCCESS Clean extraction
Battery Three. Deep in the torch barrel now. Thinking cap on.. Penatrating oil... Nope that diddnt help using threadded bolt hammered in to the battery to try and pull it out.
FAIL.. Again the battery innards have turned to mush. Though I managed to pull the back cap off the battery and removed most of the crud with a long screwdriver extension bit.
Battery 3 still has its case fused to the torch body. I have found some small "circular saw" cutting disks on flea bay on order that i will try to attach to the threaded bolt and hope to cut the case out usind a drill.
Batery Four. I dont have a plan yet..... Yeah im still working on that one !!
Has anyone ever rescued a Maglight from a simmilar situation. (or managed to get out a Battery four thats swolen up like a balloon...)
I would just bin it and get annother but they are like £45 here not cheap...
All the fun eh..
First post here..
All the fun eh..
