jrmcferren
For standard output, you can use a PR12, however, Mag hasn't used the PR12 type in years and is only 35 lumens and uses .5 amps at 5.9 volts. You have the KPR112 and is 75 lumens which is a krypton lamp which uses .75 amps at 6.0 volts. You have the HPR51 which is 90 Lumens uses .7 amps at 6.5 volts and is the type for Alkaline cells. You can also use the HPR40 which is 75 Lumens at 6 volts and .67 amps of you use NiMh cells.
