Old-Lumens
I really wasn't going to bother, since there is nothing really new about a Maglite build, except for the driver, which is new to me and the first I have tried.
The red one is a 2D LED and the Purple, (which looks blue), is a 2D Incandescent. Both have file work done on them. Nothing really new here.
The incan will have a short reflector, that came from CNQG, nothing really new there.
The LED light will have the stock LED reflector, nothing at all new there.
Both of them will have aluminum heat sinks, with a copper wrap, to keep them tight in the body, nothing new there either.
Both of them use C mag springs with copper braid and a top cap of a copper disc, so I can get 2x26650 or 2x18650 batteries in them. Nothing new.
The stock switch has the guts taken out, so I can run the positive straight through and use a momentary in place, where the stock pushbutton was. Nothing new here.
Well, finally something different. This driver board was designed by Mattaus, so I could use a linear driver that fit in Maglites and I could use it based on the NANJG drivers, but I can go up to 9 amps, (or more if you stack) and I can do either normal leds like the XM-L2 or I can do MT-G2, by just using a zener diode and 200 ohm resistor. It's fairly versatile. At least I think so.
That's all I really wanted to show you guys. I thought you might be interested in a driver that fits in the Maglite D tube and can be used with 3.--V or 6V leds. Of course, it needs an MCU with a good program and that's where DrJones comes in. He burned his lumodrv program onto some ATiny13a MCUs for me and I used them on these drivers. RMM provided the other resistors and diodes and Fasttech was the source of the 7135 chips.
These first boards are using 0603 components, but future boards will have the 0805 pads. I intend to make nothing but Maglites from now on, unless the weather changes.
So, I wanted a driver that was easy for me and something that was adaptable to XP-L, XM-L2, MT-G2, even 3-ups and I think this one will work well for me. It can be driven with as many 7135 chips as you want, up to 9 amps. Above 9 amps, you would need to stack chips.
I have added the links, so that you can find out the info you need and you might want to try some of these boards too.
