Mechanical Modding Services
blitz255
how weird i posted last week but the forum still says that you are the last one to post in here.
precisionworks
Benton Illinois
Nick, Thanks for your interest in these mods. I haven't replied to many emails since last Thursday (05-17-12) when a customer dropped an emergency repair at the shop door. Got that done on Friday & he brought in Emergency Repair #2. Shooting for late today to finish that one. I will email you right now.
blitz255
no problem man I understand you have a business to run. I got your email just as you said and I will get it in the mail in the next couple of days. I knew they were changing the website around so I really was just curious if you were seeing my posts so that the reason for all the posts and the emails. Thanks for everything.
precisionworks
Benton Illinois
Some members wanted an Ultra Groove Mod variation to make the V10R look more like a Haiku. I studied my Haiku for a while & drew up different sketches before doing this to my own (unmodified) V10R. Happy that it worked out OK so that this tube doesn't go into the Boat Anchor Collection :crackup:
Started by mounting the V10R on an internal expanding 5C collet. Since this grips the inside of the light all turning mods will end up perfectly concentric with the bore. Collet on left below, tailstock live center on right.
Image-9853934-159360590-2-Web_0_9010e501bb824f0e11585f99a210a356_1
The preliminary drawings suggested that 9 equally spaced grooves would work well so those were machined. Groove depth is the same as on a Haiku (or Ti McClickie Pak) and the grip is surprisingly good. The grooves were first machined to a depth of 0.10mm (too shallow), then to a depth of 0.25mm (getting closer) and finally to 0.40mm.
Image-9853934-159360593-2-Web_0_75a6aa0662a971caf4c1c330eaf999f6_1
The image below shows how the Haiku has wide grooves & narrow lands while this modded V10R has wide lands & narrow grooves.
Image-9853934-159411861-2-Web_0_d88379843352efd296f94eee7df99b5c_1
gunga
Vancouver, BC, Canada
Hi Barry, how much would a Haiku like mod cost? Or something like post #21? When this is done, is there enough metal left to bore to 18mm? 17mm?
precisionworks
Benton Illinois
Gunga,
The "Ultra Groove Mod" is $75 and so far there are three variations:
The original version, very grippy & full diameter on the peaks:
Image-9853934-154655156-2-Web_0_2fa3020fefe1efc25ed00b4cbdad9202_1
Version #2, done for Pete in Alaska. Minimum diameter for the grooves with the lands left .016" (0.4mm) higher:
Image-9853934-154827077-2-Web_0_c5e19d18bb0627192b64498c9af4c943_1
The latest version is what I'd call "Haiku pattern". Again the same minimum tube diameter & the same height on the lands but there are more grooves & more lands:
Image-9853934-160552128-2-WebLarge_0_9027647d880c7b645c5562b0b1560101_1
The edges of each groove/land were left with almost no radius so that they feel sharp or aggressive in the hand. Nice grip, my favorite so far.
No problem to bore for either 17mm or 18mm. Cost is $60 for either size bore.
FWIW post #1 in this thread contains lots of info.
NOTE: Bead blasting was offered until my friend sold his business & the bead blaster went away. Stone Washing(barrel tumbling) also gives a nice finish & there's no tiny glass bead grit in every possible hiding place. Details & pricing in post #2 of this thread.
gunga
How about a Haiku pattern with more radius, like version 2? Would that be possible? So version 2 is not that grippy compared to a stock Haiku? Wow, so it can be reduced to this size and bored for 18mm? WOW!
precisionworks
Benton Illinois
Certainly, not a problem.
IMO no other light has ergonomics that are even close to the McGizmo Haiku. The V10R can be modded to look similar to the Haiku but it will never feel like the Haiku does, especially in the tail swell area. The reason is that there is a large diameter diff in the Haiku & the V10R lacks that:
Image-9853934-160567347-2-Web_0_c8181ee2b2339bc2774e7c3a01778581_1
If you want the best grip from the V10R Haiku pattern you'll want the groove & land edges left crisp. More radius (more bevel or softer transition) gives less grip. Because grip is so subjective it's sometimes hard to figure out what is best.
Not a bit harder than a 30' putt at the U S Open :crackup: Actually it's more like a 10 footer. Titanium bores very nicely and the V10R is no exception.
gunga
You're a golf fan I take it?
I saw Pete's modded v10r on the weekend (Alaska Pete) and was struck by its beautiful lines and flow. It is so much nicer than stock. I think I would want the same angles and feel as pattern 2 (notice the angle near the head is much gentler) but with more evenly spaced ridges, similar to the Haiku pattern.
It is truly beautiful and greatly enhances this light. I love the bling and Trit mods, but the body slimming mod is just beautiful and functional.
precisionworks
Benton Illinois
You're a golf fan I take it?:)
Watched most of the play on Sunday. One of the best & least predictable finishes I've ever seen. Webb Simpson (the winner) surely seems like a great young player.
Thank you for your kind words.
Another member is having his V10R done in Haiku pattern & he also requested the bevel at the head:
Image-9853934-160594633-2-WebSmall_0_443ddd70a0dd70d3e303f7aa050fab36_1
That angle is easy enough to duplicate as it is exactly a match for one of my lathe turning inserts. IIRC it's 125° included angle from the horizontal tube surface.
kaichu dento
現在の世界
While I'm carrying both the Haiku and V10R Ti full-time lately, they both feel perfect. If I play with the lights the smoother reduction you did for me feels nicer and and is my favorite.
Nothing but functionality perfected with Precision's finishing work second to none. Made one of my most uncomfortable lights for cigar-grip into a joy to hold and use.
precisionworks
Benton Illinois
Thank you for your kind words Pete. I'm happy that the results are what you were looking for.
On the topic of finishing, specifically surface treatments, stone washing is an often mentioned topic on the forums. One of my long time customers wanted bead blast but I no longer offer that. Stone wash is a nice alternative to BB - it gives the light a patina look versus the more flat appearance of BB.
Found roughly 100 different types of media, narrowed that down to a dozen, got samples of five different types & settled on one. Selection of media is almost unlimited & that's just the start. The next step is to choose the density, shape, abrasiveness, etc.
McGizmo SunDrop after 48 hours of stone wash:
Image-9853934-160938614-2-Web_0_5321252ef9a14e4311fdbd2b8bb7b640_1
Image-9853934-160938610-2-Web_0_e49fabf956d1b073ac0c552120326738_1
Image-9853934-160938612-2-Web_0_eb389f4a2a7de026a70802b128997f1c_1
Image-9853934-160939133-2-Web_0_0432ec78a70b484df8d7179a8bb10753_1
kaichu dento
現在の世界
Man I wish you'd been doing this finish when you had my light - how much to do this finish, and is there a possibility of batch pricing instead as opposed to single unit pricing? I'm not a fan of BB finishing at all, because of its inherent fragility, but stonewash never gets old since the finish is just made up of pre-applied abrasions and looks as good after years of hard use as it did the day it shipped. Can't say how happy I am to see you offering stonewashing and I bet a lot of titanium users will be having you do this finish at the same time as they have their custom work done.
precisionworks
Benton Illinois
Price reduction is possible depending on the number of lights sent at one time. Email the details & I'll get pricing right back to you.
From post #2 here's "standard" pricing:
Small parts - pocket clips, bezels, etc. are $10 each.
Titanium or Stainless Lights:
Key chain size - $30
Single cell (1x123) are $50
Two cell (2x123) are $70. Price covers light with all attachments (body, head, bezel, clip, etc.) I will disassemble & reassemble your light or you may take it apart before you send it.
Please note: Minimum price to tumble any item is $50. That means that a single clip will cost $50 & five clips will also cost $50.
precisionworks
Benton Illinois
Stone washed SunDrop compared to my personal SunDrop:
Image-9853934-161033764-2-Web_0_78ac9941665b505233e0f43c3d1e01d5_1
Image-9853934-161033770-2-Web_0_524e914a5896d55a101062b52fb2ed6a_1
Image-9853934-161033778-2-Web_0_6cfe1cf0208f224e4602938d6a055823_1
All in all the stone wash is exactly what was desired. Still have a little work left on this SunDrop as there is one area that did not get burnished (red arrow below):
Image-9853934-161035487-2-Web_0_85db2423c02210cb3aa6ead4395c1144_1
Not a big deal, just a few more hours in the barrel to make that match. Knew I should have waited to wash & dry the media & the tumbler. Reminds me of Yogi Berra's famous saying "It ain't over til it it's over."
precisionworks
Benton Illinois
Put one of my own V10R Ti lights into the tumbler yesterday. Looked at it this morning & it's just starting to color.
EDIT on July 4 - added a pair of factory bead blasted Sebenza scales which were starting to show some wear marks. Also added a ZT0560 titanium scale.
Will post photos as each part reaches the 72 hour mark.
precisionworks
Benton Illinois
The V10R Ti was left in the stone wash until this morning, about 84 hours total. The purpose of the longer time was to see if the bezel etchings would abrade away ... and they did not :)
Image-9853934-161659975-2-Web_0_a7d22283e43a27f2d3ff7defe812e05f_1
Image-9853934-161659978-2-Web_0_9617922c5c38607b3379b9ad4f5b8592_1
The knife scales seemed to reach full color after "only" 48 hours & they also came out this morning.
Chris Reeves Sebenza:
Image-9853934-161659981-2-Web_0_29548c18ec603af149f7a918b7de65dd_1
Zero Tolerance 0560:
Image-9853934-161659986-2-Web_0_786e252a64fb06db6cc27f65c528b0df_1
precisionworks
Benton Illinois
I figured that a number of members would comment about the V10R but instead quite a few wrote about the Sebbie :)
As far as surface prep before stone wash ... none. Disassembled the knife & placed the scales & pocket clip into the barrel.
These images should help give a better feel for the results.
Image-9853934-161699976-2-Web_0_754db83e81fe2928cda132b6c6bfca7f_1
Image-9853934-161699979-2-Web_0_96c92cc3578f67f6c10d9577e7128348_1
Image-9853934-161699982-2-Web_0_dc993164d2f7f4a1e119faaf6ca38cb2_1
Image-9853934-161699985-2-Web_0_5fff5fffaf06c5032a22056db0b19f0a_1
Image-9853934-161699988-2-Web_0_fc9dfd412e4593cb8b81235746fc509b_1
Image-9853934-161699993-2-Web_0_5a7978d19a8dc65786917d3c3469686a_1
Image-9853934-161699997-2-Web_0_ee137a4a15e47ba620b6d2a2ad8ddaa5_1
Cost for a Sebbie or any knife with two Ti scales & a clip is $50. Cost for a one scale knife like the ZT is $25.
