nasa779
hi guys, im a mechanic and i need a durable small bright penlight, im currently using an eagletac t100c2 thats so far taken a hell of a beating
ive been looking at the 4sevens preon 2 and the eagletac pn20a2, but i question how shock resistant they are
online
2) Budget: An easy question, but you may change your mind after answering the rest!
Less than $50.
3) Format:
penlight
4) Flashlight-specific format/size:
Every day carry small (2-4 inches).
Every day carry medium (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
Incandescent (known for superior color rendition)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to navigate a dark room or read a map (0-10 lumens).
I want to walk around an unlit rural area (50-150 lumens).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
6 inches to maybe 4 feet
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
doesnt matter
Critical, i want something that will be able to take a beating, temporary high heat, oil, solvents, grease, and it will be dropped.. so shock resistant
12) Switch Type and location (choose all that apply):
I want a forward clicky (Helpful for momentary activation and signaling).
I want a reverse clicky (For use with multi-mode/level lights).
I want a tail mounted switch (found on the majority of today's high end lights).
A simple on-off with only one output level is fine for me.
I want 2 light levels.
I want multiple light levels.
I want a strobe mode. want, but not important
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
Stainless steel (durable, but much heavier than aluminum)
Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Pocket clip
online
Less than $50.
3) Format:
penlight
6) Manufacturer:
doesnt matter
Pocket clip
