Robust pupillary reflex keychain penlight
Frank E
Aberdeen, United Kingdom
I'm looking for a keychain LED penlight to keep on my keychain. It's principally to check casualties' pupillary reflexes, airways. I guess I'll also use it for general things like checking under my seat at the cinema for dropped things
I've currently got a little 1 x AAA Maglite with eneloop. It's robust enough but it's incandescent and the CRI isn't good.
I'm not looking for anything fancy like a Welch Allyn. The other'proper' ones at the paramedical supplies sites aren't very well engineered to keep in pockets and end up breaking at the threads in a short time. Disposables are even worse.
Preferably a few different power levels, focusable, good water resistance, replaceable cell, ATEX even better (though might buy a different ATEX one that takes 2 AAA size).
Are the 3.6V lithium cells c. AAA size?
I was thinking of something along the line of STREAMLIGHT 88049 ProTac 1AAA but I haven't heard of the brand.
I'll have different one for my backpack first response kit and a different one again for home first aid kit..
Known brand.
Frank E
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__x__This will be mail-order or Online (location doesn't matter).
UK-based
2) Budget: An easy question, but you may change your mind after answering the rest! :)
__x__I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
_x___I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
_x___MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_x___LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
Known manufacturer
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
_x___I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
_x___I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__x__I don't care
__x__I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
Just enough to cause pupillary reflex night or day, examine and airway, read ID, documents, check for coins under a cinema seat..
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
Short range, focus ring.
__x__Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
_x___Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
__x__30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
Other: Until the ambo arrives and leaves if I stay
____Not Important (A "night-stand" light).
__x__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
__x__I want a body mounted switch (near the head, like on a Maglite).
___x_I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
__x__I don't know.
___x_Other, please specify________Nothing that will acidentally swith in my pocket____________.
____A simple on-off with only one output level is fine for me.
__x_I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
___x_I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
_x___Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
__x__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
other IPX+
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
_X___Other_On keychain in pocket with coins, wallet, also standby____________________________________________
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
knucklegary
NorCal, Central Coast
Maglite has an upgraded Solitaire warm LED called Spectrum. 68lms should be sufficient enough to dilate pupils?
...check it out
bykfixer
Dust in the Wind
The Fenix E01v2 is a tad bit smaller than a solitaire. Starts out on a low that can dialte a pupil without the person hollering "holy crap man what are you doing to me?" Yet when you need bright it can be as high as 100 lumens. Fenix makes good products. The v2 uses a twisty head though for on/off/adjust levels.
Streamlight is a good company. They have an actual EMS light called....the EMS. But it's a 1AA so a bit large for a keychain. It too starts on a pupil dialating low. Their protac 1aaa is like a solitaire or microstream size. Another nice little flashlight.
The solitaire spectrum warm is a nice little 1 setting light.
bykfixer
Dust in the Wind
Thanx! I'd never heard of that. Any chance an LITT switch would work in it?
aznsx
Phoenix, AZ USA
Thanx, Byk! I had no idea that was a new(er) LED Solitaire in that photo! I'd assumed it was an inan, like the one in my hand here. An 'extra' AAA switch will be in my next order. That switch, plus one of those Solitaires (like KG linked to) for only another $18, and I can get a little light I'll actually use, and support 2 U.S. companies in the process! What a deal! "Wrap it up, I'll take it!"
KITROBASKIN
New Mexico, USA
Columbus, Ohio
Nitecore makes a dedicated EMS medical inspection light, the MT06MD. It's a 2xAAA penlight. No blue wavelengths that might damage a sensitive retina. Always starts on low. Comes with a pupil gauge imprinted along the barrel of the light for fast and reasonably accurate dilation assessment. High CRI emitter for better visual inspection.
It's worth serious consideration.
Frank E
Thank you everyone. Sorry, I forgot about this thread, life popped up.
I was at an exhibition & conference last week, met Peli and they gave me a 1910 flashlight, It is 1xAAA LED with 2 power settings. The lowest output is just grand for pupillary reflex and the highest output for general use.
I'll think of something to attach it to a keychain.
Many thanks again.
bykfixer
Dust in the Wind
Many thanks again.
Streamlight makes one that is big for a key chain but would be good for carrying in an equipment bag. It's designed for pupulary reflex. The 1AA Streamlight EMS. It has a high as well for times more light is needed but starts on low.
IMA SOL MAN
The HEART of the USA.
Variable output to limit the amount of gore illumination in case you are squeamish. ;)
