sbbsga
I just found out that the LED on both my EA4's are lit up very dimly during the voltage readings - switch lock-out and tail cap reconnection. The same thing happens on my TM15W too. But they are off after that.
If they produce a version with a low mode, I'll buy it. I can't see spending so much money on a hobbled light.
Sometimes a missed opportunity or poor design choice is just that. There was no design tradeoff in choosing not to implement a proper low mode, just thoughtlessness as to how the light would be used by many people. As close as it is to "great" in my book, it's not great without a low mode. I like many things about the light (form factor, battery type, waterproofing / build, lockout mode, etc.), but will wait until they fix that design flaw. Hopefully someone will read up on prospective customer feelings when designing the next version. I am also avoiding the Fandyfire Rook because of the glaring lack of a low mode. I don't intend to drop a non-negligible amount of money on a light that I consider to be uselessly hobbled.Isn't everything really about comprimises?
I for one would have to agree, this light just about perfect in its current design. If you want a moonlight mode get a smaller light, for outdoors the low is just right for walking and turbo is just a press away for anything that goes bump in the night.This light is being marketed as a searchlight. Working SAR I dont need or want a lower low than 65 lumens. When mine arrives it will be a utility belt light to go along with my main fenix tk75. I love moonlight and firefly modes but not in a searchlight. Just my opinion.
Happy New Year everyone! It's 2am and 1F out here in the wilds of Iowa, and I just got back from running #1 son over to his girl friend's house. I just got my NW EA4 from the Post Office this morning, and loaded it with a set of 2022 EA91s. I left it in the car all day, and took it out just now when I got home, so you know it was cold. Did some distance shots and it really is a nice little pocket searchlight. Easily lit things up 175 m away. But the really interesting part was that after about 5 minutes of play out in the cold, it showed 5.8 volts when I put it into lockout. Yet when I pulled one of the cells 5 min later to get the date off of it, it showed 6.2 v when I put it back together. Amazingly resilient little cells, aren't they.
I personally think 65lm is fine for a low. When I was walking back to the apartment from playing around, it was just enough to light up the ground around me. If I need anything less than that, that's why I carry my SL ProTac EMS (3.6, 10, & 60 lm).
On an unrelated topic, does anyone know what the two long numbers are trying to tell us?
PS: No rattles.
I'm a bit disappointed with my EA4 I received today. It looks like the bezel was either cross-threaded, or the threads were cut un-square on the body. Plus there's a rattle even when I remove the tailcap and batteries, with the switch depressed as well. Anyone else notice this?
Right now my only concern is about the switch assembly working life ....time will tell !
Describing a failure to include a proper low mode as a plus is just denying the obvious; a light without a proper low mode is not just about perfect. A moonlight mode would be all right in addition, but at least I'd like to see a light which doesn't imply that people need a wasteful 65 lumens to see one's way in the dark, etc.. Nor is it a meaningful answer to state that I can carry another light to remedy this failing. Of course I can-- the point is that I don't intend to carry two lights because one of them is hobbled; I'll wait for the non-hobbled one.I for one would have to agree, this light just about perfect in its current design. If you want a moonlight mode get a smaller light, for outdoors the low is just right for walking and turbo is just a press away for anything that goes bump in the night.
No, I just tend to state the obvious without blinding myself. You obviously don't like it when anyone "insults" your gear, but I take a more rational approach. If you go back and read my post again, maybe you'll get it. The point is that the silly absence of a real low mode wasn't based on a useful design tradeoff; it's just a dumb oversight that makes the light less all-around useful. Sorry you self-identify with your lights so much, but sense is sense.Wow....uselessly hobbled? So more light is more useless then less light? Are you blind by chance?
These arguments that one should ignore a missing feature by carrying more lights just don't make sense to me. Let's consider your backup argument: of course I have backup lights. We have backups because the primary light may fail, not to use because the primary light has missing features. In this case if your "backup" were to fail, you'd be left without a proper low mode.Agreed. And I'm going to guess you have a backup stashed away (and another backup to the backup?) anyway, which could serve other tasks with lower lumens. Trying to have an "all-in-one" would be a very risky situation in a potentially dangerous situation.
65 lumens is never "just enough to light up the ground" around a person, for anyone with properly working eyes. With night adapted eyes 1-3 lumens is plenty for lighting the ground around a person, enough to serve as an aid in night hiking, and I know of some people that would use even less. There is a vast gulf between 1-3 lumens or so and night-vision destroying, battery-wasting 65 lumens. A low mode of around 10 lumens, multiplying maximum battery runtime by around six times, would make so much sense that the failure to include it ignores how many people use their lights.I personally think 65lm is fine for a low. When I was walking back to the apartment from playing around, it was just enough to light up the ground around me.
The point is that there was no useful purpose in leaving out a low mode in this light. For general purpose use, I'd rather have one all-around useful light to carry instead of a bunch of lights because features were left out which should have been included on some of them. That's the reason that I usually carry just one light in my pocket, instead of one for throw, one for spill, etc. I also tend to just put one light in my glove box, which I would also like to not be hobbled by failure to include features that would have been involved no drawbacks to include.
There's just no way to spin the failure to include a low mode so that it doesn't make sense. Some can pretend they would never use it (because they like to waste battery life, I guess the argument runs); some can pretend that they would prefer carrying multiple lights. None of this comes off as anything but a heap of rationalizations for a design flaw.
I stopped for a sec after reading that you " just got back from running #1 son over" lol. Did the light make a nice hand warmer in that super freezing temperature?
