New Wurkkos TS10, a Floody Titanium light with Triple High CRI LEDs plus RGB Aux for under $50
raggie33
*the raggedier*
The free light is nice for the price for sure
raggie33
*the raggedier*
Its lowest setting is even lower then the normal ts10 I love super low in a combat or stealth situation it comes in handy
vicv
Southern Ontario
What the titanium one? My aluminum low is so low I can find no use for it. I've set the floor the level 5 which is just about perfect for navigating in the dark with sensitive eyes. Ya $58 shipped is great.
raggie33
*the raggedier*
I have to sit in the dark for a hour to get my eyes adjusted to go that low well the old ts10 low I'll have to check out if I can use the new one after eyes adjust to dark
jon_slider
congrats, so glad youre enjoying your new lights
fwiw
the default lowest setting in advanced smooth ramp is the lowest
lower than advanced stepped ramp.. and lower than both simple mode smooth and step ramp
they can all be changed to your preference
jon_slider
So you set the ceiling to 90. Which is what you recommended for my aluminum model as the top of 7135 and 120L. But you claim your tits10 sustains about 225 lumens. How, if level 90, your max level on that light, is only 120L.
I was browsing some of my photos and thought you might be interested in my Ti TS10 cheat sheet and sustainable output configuration notes
It seems that level 90 on a Ti light is about twice as bright as level 90 on an Aluminum light
this is the cheat sheet for my Aluminium settings, I use a ceiling of 120, not 90 as in the Ti model
vicv
Southern Ontario
Gotta wonder why they made the factory settings for the one with worse thermals twice as bright.
I've got mine setup pretty much the way I like it.
5-120 ramp
Stepped 7 levels plus turbo( I barely use turbo but like having it)
Level 90 memorized mode
55c temp ceiling
And I rarely go past my memorized mode either. So battery life has gotten better. Probably use it equally between actual use and high aux so I charge every other day
jon_slider
I dont really know.. my guess is that was an unintended consequence of changing the low mode spacing..
another change is that the Ti models ship w Advanced ceiling set to 150/150.. it was a mistake, for reasons I wont try to explain.
I change my Ti ceiling to 90/150, just above the sustainable output of 225 lumens... which is similar to the Max output of my HDS, which is 200 Lumens
glad you have found the settings that work for your needs ;-)
vicv
Southern Ontario
Misty night tonight but not particularly cold. Walking the dog and cranked the little guy up to high/120. Unusually I'm I'm level 4/5. It gets pretty warm on high. Temp set to 55c. Was pretty damn bright though. Had to double check ceiling was set correctly. And it was
