raggie33
*the raggedier*
- Joined
- Aug 11, 2003
- Messages
- 13,673
i still prefere eletric its going to blow all are minds someday
Yeah, its funny how conversations go. Sometimes the topic changes so quickly, I find while politely waiting my turn to speak on a topic, it changes, and it would be odd to put my two cents in on the earlier topic.+
We're so goofy, from a small lawnmower engine burning a bit of oil, to Top Fuel jobberoos.
Caught myself watching a NHRA competing a while back,
the superchargers used to make the 11,000hp use 2,000hp in the process to do that.
Wrap your head around that one...
Sorry, I should have clarified, I was speaking to conversations in person, not online.
Yes, you are right, about "online" conversations... I used the "Reply" option to skip over raggie's post about going electric.
Thanks
I'm just happy to see you asked CPF members how to properly check the oil of a lawnmower instead of asking your cellular phone or an orb named Hal sitting on the dining room table.
Yes, I learned a long time ago, that it is generally a good idea to READ assembly instructions. One time I bought my wife a fairly rigid plastic bird cage. One that had multiple pieces that snapped together. The instructions gave a step by step procedure. Yet... looking at the picture seemed like it was very straightforward. Wrong! I snapped a piece in place, only to discover that I needed to remove it so that another piece could be snapped in first.+
Not assuming is a good tactic
I'm pretty sure I have NEVER read the instructions for a lawnmower or other small engine powered equipment.I'm pretty sure I have or once had a small engine that had instructions to screw the dipstick all the way in when checking the oil.
+I'm pretty sure I have NEVER read the instructions for a lawnmower or other small engine powered equipment.
Boy, was I concerned that I was going to break it trying to remove the piece that I put in place out of order. Luckily I was able to get it apart. whew.
Briggs & Stratton say better air filtration and more precise machinery allow the oil to stay cleaner. But, to me the heating and cooling could add condensation to the oil so I'd still change it every other year at most. It's pretty easy on most pushmowers.So, anyone here purchase one of those - never needs an oil-change lawn mower? They're something I can't get my mind wrapped around.
I noted that they do make different quality engines, (just as honda does) some with cast iron cylinder sleeves, and some have aluminum blocks.
