Okluma DC0 Titanium Flashlight Review (Nichia 219c, 14500)
zeroair
I submit this review of the Okluma DC0 humbly for consideration to your review forum. Thanks!
This light is absolutely all the rage in the flashlight world right now, and I have been wanting to get my hands on one for testing (and because honestly it looks fantastic.) This is the Okluma DC0, a titanium 14500 light with a Nichia emitter. Read on for photos, testing, and thoughts!
Official Specs and Features
Here's a link to the official product page.
Versions
Currently there is just this version. But there have been announcements and teases that show a bunch of future releases: Zirconium and also aluminum body materials, and a Nichia 219b emitter option, as well as a narrow optic, and possibly a programmable driver!
Price
This light lists for $449 (and currently sold out).
Short Review
I love the externals of this light. The feel is great in hand, and is a great size. I would prefer the light to operate on both AA and 14500 cells. It's also a long for being an AA sized light
Long Review
The Big Table
Okluma DC0
Emitter:Nichia 219c (4000K)
Price in USD at publication time:$449.00
Cell:1×14500
High RuntimeMedium Runtime
LVP?Yes
Switch Type:Mechanical
On-Board Charging?No
Claimed Lumens (lm)500
Measured Lumens (at 30s)291 (58.2% of claim)*
Candela per Lumen2.9
Claimed Throw (m)
Candela (Calculated) in cd (at 30s)75lux @ 3.708m = 1031cd
Throw (Calculated) (m)64.2
All my Okluma reviews!
  • Measurement disclaimer: I am an amateur flashlight reviewer. I don't have $10,000 or even $1,000 worth of testing equipment. I test output and such in PVC tubes!! Please consider claims within 10% of what I measure to be perfectly reasonable (accurate, even).
What's Included
  • Okluma DC0 Flashlight
  • Vapcell 1000mAh flat top 14500 cell (not shown here)
  • Carry Pouch
  • Okluma carry coffin
  • Birth certificate and light details
  • Sticker (1)
  • Magnet (2)
Package and Manual
Okluma is known for quite a few things, and a "robust package" is one of them. The light ships in the box seen above, and that box can rightly be seen as "part of the packaging" since the contents are custom cut for Okluma. See below the branded foam!
There is no manual.
Build Quality and Disassembly
As I said above, the look of this light is incredible. It's very "Okluma" – it shares the four knurled sections in the middle from the DC1. It's nice to see the heritage maintained!
The build quality is great, too. This light has a sort of a stonewash (or something) finish and because of this is has an extremely unusual feel in hand. Smooth in the parts that are smooth and grippy in the parts that are grippy.
Even the parts that are grippy though… this is hard to explain… it's almost like this light wants to and is even desperate to jump out of my hands and meet the floor. I've held… quite a few lights… but with none have I had this sensation more than the DC0. I have not dropped it, though. Testament to the grip areas? Must be, because it's stayed securely where it should be.
With all the knurling in the body, one other place you'll need knurling is on the head, for cell swaps. Yet there is none. So you'll need to firmly grip the head for removal. On the one hand, I'd like to see some knurling here for better grip. On the other, I get it – branding is being maintained from other lights.
The switch is just recessed – tailstands work fine.
I find these threads to be "very titanium." If you've had a titanium light, then youll know what this means. If you haven't then… they're just a little gritty. This is the nature of titanium, so you would already expect it, but it doesn't make it any more pleasant.
Keeping slight "together" pressure of the parts when loosening or tightening the head will make the threads much smoother. I also find that the start could be better. I don't know the terminology but having a better ramp to get the head and body started would be much better than what's there.
On the inside, there's a spring in the tail, and a brass button on the head. That driver is a 15mm driver, so could be swapped with any other 15mm driver (including something like the programmable 15mm Dragon Mini). Unfortunately even with the Dragon Mini you won't be losing the annoying PWM (and you don't gain AA support).
The tailcap unscrews easily too, allowing switch maintenance. The cell tube is not reversible. Likely you will not want to remove the tailcap much, because the clip will rub the body. I'd prefer cell swaps from this end though, because the threads are much shorter. It can just be seen here (and I didn't really notice it til just taking the tailcap off now and it falling out) that there's a little washer around the switch. It's wavy, and probably really supports contact between the switch/tailcap and the body. So be careful and don't lose that! (And those aren't listed for sale on the Okluma page.)
Size and Comps
No official size specs, but here are my measurements:
Diameter: 18.46mm
Length: 102.55mm
Weight (with cell): 78g
The DC0 is a great "user sized" light.
The titanium is 6al-4v titanium. That's the same variety of titanium used in (at least some of, but probably all) Hanko Tridents.
Like I said elsewhere, the DC0 is very long for what it is (an AA sized light). I don't have a longer tube light AA sized light, in fact. (Something like the Malkoff AA would probably be longer, but that's a different class light).
Note that below it's not even the only mechanical tail-switch light. The tool, Ultratac, and Convoy (all shorter) also have mechanical switches.
Retention and Carry
Okluma includes a standard Okluma clip on the DC0. It's a very good clip, and coupled with the slickness of the body, the small mouth is still easy to use on pants. The clip does touch right on the knurling, so you'll eventually wear pants using this clip, probably.
The clip is of course good – this design has great spring. It's not deep by any measure, but the light is long enough that the balance is good.
Power and Runtime
The DC0 is powered by a single lithium ion cell. A cell is included with the purchase. That cell is the Vapcell 1000mAh 14500 seen below. It's a flat top, and rated at continuous 3A discharge. I actually reviewed this very cell a good while back. Read that review here.
The DC0 will not work at all with any AA cell (primary, NiMH, etc). Anything under 3V will not work in the DC0. That's a big disappointment for me, since even the smallest light seen in the size comparison above supports both AA and 14500.
The cell is fully inserted into the light in the photo below. It sticks out quite a bit.
But like I said, a little "together" pressure when screwing down the head allows easy installation. Button tops will work in there too.
Here are a couple of runtimes. High and Medium. The light is rated at "~500 lumens" but I measure nowhere close to that. Here's the thing – it doesn't actually matter. For the way the light is used (an EDC role) owners categorically love this light. I'd say that means one thing: lumens don't matter.
These outputs are unregulated, which is a little disappointing too. I'd like to see sustained output at the ~300 lumen High.
Medium is more stable, at least.
I don't really agree that lumens don't matter, but my "always carry" light is an AAA light with some few lumens (looks like 115 lumens claimed).
So don't buy this one because it's a barn burner of output. But buy it as an easy to carry, always there, backup light.
Modes and Currents
ModeMode Claimed Output (lm)Claimed RuntimeMeasured LumensTailcap Amps
High5002761.31
Medium330.19
Medium Low0.01
PWM
This is one of the places that bothered me about the light. Before I purchased the DC0, the product page had some verbiage about "constant current" which I mistakenly took to mean that there was no PWM. I was wrong (not the page), but the light does have pwm on all modes. The higher two aren't a problem, but the lowest mode is venturing into a timescale that could be visible to the distinguished PWM sensitive people (like myself).
Don't consider this a deal breaker, but do consider it.
For reference, here's a baseline shot, with all the room lights off and almost nothing hitting the sensor. And here's the worst PWM light I have ever owned. Also one of the very first lights I ordered directly from China!
User Interface and Operation
The DC0 has a mechanical clicky tail switch. It's a forward clicky, which means momentary actuation is possible.
It's a great switch – only stated as a "Forward Clicky Switch" but it's most likely a McClicky. It's very sensitive, with around the same press required for momentary as my Hankos and BOSSes.
Here's a UI table!
StateActionResult
OffClickOn (Mode memory)
OffTapMomentary (Mode memory)
OnTapNo action
OnClickOff
OffTap (multiple)Mode memory, then mode advance (LMH)
The DC0 is pleasantly uncomplicated with strobes or beacons or whatever, and there's no "ridiculously fast stepdown from turbo" to mention. Just simple three mode output.
A programmable driver is available. It's an extra charge, and I'm not covering it here (as it's not what I have). Between this one and one I don't even have, I would unequivocally recommend the other one, though. That driver is a FET+1 running Guppy3drv.
LED and Beam
In my copy of this light is a Nichia 219c 4000K and a dimpled floody optic. Jeff (of Okluma) recently announced (the day after my purchase, grumble grumble) a narrow optic (my preferred) and a Nichia 219b option (my favorite emitter period.)
The 219c is great. Even if you go for the narrow optic, the 219c is still great. I do believe the narrow optic is a better choice for this light, though.
These beamshots are always with the following settings: f8, ISO100, 0.3s shutter, and manual 5000K exposure.
Tint vs BLF-348 (Killzone 219b version)
Test light is on the left!
I compare everything to the Killzone 219b BLF-348, because it's inexpensive and has the best tint!
Conclusion
It's not often that I get to the end of all the writing and feel that my real thoughts on a light haven't been conveyed. I love the DC0. There are a bunch of things I don't like about it though. Jeff is going to be making an aluminum version, which I think will suit me much better than this titanium. It'll be cheaper, I'll get the driver/optic/emitter I actually prefer, and it'll probably be lighter, too. But I can't not support Jeff, because 1) he's a great guy, and 2) his warranty is absolutely unparalleled. The DC0 titanium in this format doesn't quite do it for me (and that makes me an outlier among DC0 owners). But I'm pretty certain another DC0 will do it for me, and I hope to get one of those soon!
What I like
  • Excellent finish on the titanium
  • Robust design
  • Use of Nichia emitters (with 219b option)
  • Use of optics that can be swapped (flood or narrow)
  • No part is prohibited from changing (nothing is glued down)
  • Amazing ("no-questions-asked lifetime") warranty
What I don't like
  • The price
  • Threads need better start
  • Head needs some knurling
  • 14500 only, no AA support
  • Light is too long
Notes
  • This light was purchased by me. I was not paid or compensated in any way to write this review.
  • This content originally appeared at zeroair.org. Please visit there for the best experience!
jon_slider
You are my favorite reviewer.
Thank you for the great photos, for verifying the actual output, and for testing if the light has PWM.
Like you, I am disappointed that the light is LiIon only.
(Lumintop manages to build a Ti AA light with dual fuel capability, for 1/10 the price)
Other things that dont work for me
PWM
no Sublumen mode
price
gritty threads
(normal for inexpensive Ti lights, but the hanko D10 Ti has smooth threads.. it IS possible, at this price point.)
Longer than any other AA
the clip rides on knurling... (pocket grater)
what I like
the clip :)
the slender 18.5mm diameter
zeroair
Thank you! Kind words!
Very welcome.
Exactly. At this price point it'd be reasonable to buy a bunch of Tools and pull the driver. You'd still have PWM but at least you'd gain AA support!
PWM
no Sublumen mode
price
gritty threads
what I like
the clip :)
Agree, agree. :D Thanks for the comment!
the0dore3524
California (Bay Area)
PWM
no Sublumen mode
price
gritty threads
what I like
the clip :)
Hear, hear. Nailed it.
calipsoii
Good review zeroair!
I was also wondering about the constant-current claim on the website, so thanks for clarifying the driver operation. I'd like a DC0 but the price is just beyond my reach.
Cheers!
- calipsoii
XC351
My first truly custom light
