Olight Marauder X7vn - 2017 Popcan King
Skylumen
10% correction
Start Up: 16,200 Lumen, That's 5400 Lumen Per LED, or 1350 Per Die
ANSI: 13,900 Lumen, That's 4650 Lumen Per LED, or 1160 per Die
This is TN36UT HD Edition: XHP70 CW Dome On, Lumen 13,400/12,600 - Lux: 48K/45K
So.... 2800 Lumen brighter at start up, and 1300 Lumen brighter by ANSI
Skylumen
10% correction
2800 lumen brighter at start up is significant. There are plenty of room left to upgrade so I think I can surely reduced the drop to 1300 even less ;-)
Still need a freaking new 9V battery. Walmart time! Or someone go get one for me so I can rewire this thing. LOL
VNguyen
Always wonder about these HD LED. Now proof that they are more potent than the other xhp70 especially with drivervnx2 pushing it.
cclin
Vinh, Olight marauder x7 can't do tailcap lock-out & DriverVNX2 has no Electronic lockout capability! Is there any way you can solve this issue??
b8llzblue
that is simply amazing. i did not expect to see those numbers. i would have assumed it would have very similiar numbers to the tn26utvn. its basically the same light but different looking host.
and you usually push thrunite lights pretty frickin hard, so i actually did not think it will pass up the tn36utvn.
but you know what, im betting on your vn driver is whats giving the olight x7vn the extra lumens. the tn36utvn has stock driver.
so which light has the better thermal management? the tn36utvn already gets super hot in under 2 minutes on turbo.
the olight has to be the same right?
b8llzblue
Yes spec soon. Batteries are charging.
X65vn later. One battle at a time...
x65vn would be cool, but the olight x9vn should blow it out of the water! it claims 12,000 lumens stock with the new fan cooling feature!
ven
Manchester UK
Awesome work as always vinh, unstoppable in pushing the boundaries...................ok burning them away:D
noboneshotdog
The calm before the X7vn storm. I think Vihn is going to blow our socks off with this one!
Impossible lumens
I think it's a little too rich for my blood. I'll have to see when it comes out along with the X9. I would probably rather go with Olight. I'll be interested to see the x7VN when finished.
ProCharger
Warrenton, MO
Vinh you don't happen to have a tn36utvn on hand to compare specs with side by side do you? Even if the battery is inflating the numbers they would both be inflated equally....or in other words a fair playing field.
arKmm
UK
The X7. The light we have all been waiting for..
Any readings on throw yet?
Boots45acp
Arizona
Will this X7vn replace my beloved TN36UTvn 13,400 lumen Spec 1 ??
Decisions, decisions....
So tempting....
