Prepped
- Joined
- Aug 16, 2015
- Messages
- 325
+1 on tightening the tailcap. I had an issue with mine flickering. It REALLY needs to be tight.
Assuming the cell is fully charged, it sounds like your cells are struggling with the load and are tripping the protection circuit, try a primary cell to verify before returning.Sorry if this question was answered in the previous post about Turbo mode runtime but I am wondering if my light is working properly or if something else is going on. I just got it in the mail yesterday and I love it. This happened last night to me though, after running Turbo mode for a few minutes (not more than 5) the light shut off and wouldn't turn back on in any mode. I unscrewed the cap and screwed it back on and then Turbo mode came back on. But it went out again so I did the same thing. This kept happening until Turbo wouldn't stay on for more than 10 seconds and after it went out the light would not turn on in any mode. But as soon as I unscrewed and screwed the tail cap back on the light worked again. Does this just sound like a battery problem? I thought I put in a fresh RCR123 but maybe not. I did replace the batter this morning and the light seem to be good. I ran Turbo for a minute or two and it didn't shut off.
Any insight?
Thanks!
I wonder about current draw running on a CR123A primary.
With his Zebralight SC32w flashlight in H1 mode (the highest mode), CPF member recDNA measured current draw from his CR123A battery at 2.2-2.4 amps. Presumably, the Olight S1's turbo mode would be in the same ballpark. Unfortunately, that is significantly higher than most CR123A batteries are rated for. The maximum continuous discharge current for a typical CR123A battery is only 1.5 amps.
For this reason, recDNA decided to stop using the H1 mode. The lower modes work fine, with current demands below the 1.5 amp threshold.
Has anyone measured the current drawn from a fresh CR123A battery in turbo mode on the Olight S1? I would love to hear what you are getting.
Any insight?
Thanks!
Funny, I just noticed that today. Initially alarming.Neat little light, just got mine. Quick question-is there a lens over your optic? I can reach right in and feel the "nub" in the center...
What cell do you use? If it's an old, worn out cell, it can shut down before reaching low voltages if used in a high drain device like S1 in max mode.However, after using on max for some time the light shuts off. Could nit turn it back on. So, I placed the cell in the charger and it reads 3.77V. Is it supposed to do that?
