Since this is getting some attention, I set up this informal test to try and show how much current draw can vary depending on the cell used.
Pics...
Host: Modded 6P with a ~1 year old DX-MCE drop in.
Cells from L-R
AW-IMR (I have two on loan, but only 1 is pictured... thanks Big-C!!)
Samsung ICR18650 (Pink)
Unsure of brand (light teal)
Sanyo 18650 (red)
Panasonic 17670 (purple)
All cells freshly charged in a WF-139, measured 4.17 hot off the charger
AW-IMR #1 = 2.49A
AW-IMR #2 = 2.77A
Samsung ICR18650 (Pink) = 2.10A
Unsure of brand (light teal) = 2.05A
Sanyo 18650 (red) = 2.30A
Panasonic 17670 (purple) = 1.65A
At one point I had some blue and green Sony cells but their internal resistance was horrid.
Details of my setup...
DX:MCE - Remove the large spring. Tighten brass pill all the way down into the reflector. Wrap tightly in copper tape. These measures will help increase thermal conduction and help ensure a solid electrical contact. I generally try and use P60 hosts and modules without the large spring. if yo udo it right you can get the brass pill to bottom out firmly against the body tube. This increases thermal conductivity, and helps to reduce the possibility of an intermittent body contact.
Surefire 6P - Grind bezel down so its about 2-3 mm shorter than stock. This helps ensure a firm electrical contact between the brass pill and body tube. In the macro pic you can see a slight gap between the shoulder of the light and the bottom of the bezel. Mine has ben spun on a lathe to accept an 18650 cell.
Z41 - Stock Z41 has very low internal resistance. Its also has a very high current capacity and doesn't require current to flow through the tailcap threads. Lubed threads can be a high resistance conduction path.
Pics:twothumbs
